+ Reply to Thread
Results 1 to 3 of 3
Thread: Plasma Cutter Torch Controller
  1. #1
    3v0
    3v0 is offline
    3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,464
    Blog Entries
    11
    Default Plasma Cutter Torch Controller
    A friend is building a CNC table for his plasma torch. The stuff for the X and Y axis will be purchased as kits.
    He was wondering if I could build a Z axis controler (torch height controller).
    The torch needs to be positioned away from the work based on the current flowing through the torch to the work.
    Some other means of measuring the torch to work distance would prevent the controller from slamming the torch into the work.
    On the surface this seemed to be a workable project.
    What do you think ?
    BCHS/3v0's Tutorials
  2. #2
    jbeng Good jbeng Good
    Join Date
    May 2004
    Location
    Illinois, USA
    Posts
    530
    The folks at Plasmacam make tables for plasma torches. You might take a look at their design and see how they do it. Torch height is certainly done via software controlling the Z-axis, but I don't know if they use any type of feedback to do this.
    Jeff
    Jeff
  3. #3
    3v0
    3v0 is offline
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,464
    Blog Entries
    11
    It does, they call it Digital Height Control™
    It adjusts the height based on the voltage between the tip and the work. Not the current as I said in my OP.
+ Reply to Thread
  1. Xbox 360 Tilt Controller
    By adamthole in forum Electronic Projects Design/Ideas/Reviews
    Latest: 20th January 2007, 05:24 PM
  2. closed loop controller that receives set point updates TXRX
    By usacanbiteme in forum Electronic Projects Design/Ideas/Reviews
    Latest: 28th September 2005, 09:02 PM
  3. Help With Temperature Controller
    By bryan in forum Electronic Projects Design/Ideas/Reviews
    Latest: 30th June 2003, 12:18 PM
  4. using shift and stage register with controller
    By waqar in forum Micro Controllers
    Latest: 18th April 2003, 06:37 AM
  5. PBX question
    By waqar in forum Electronic Projects Design/Ideas/Reviews
    Latest: 30th March 2003, 06:21 PM
Tags for this Thread
