I'm making a temperature controller, and I've got this far (see attachment), but I need to also have a digital readout showing the set-point set by the variable resistor (in degrees C). I thought about using a bunch of comparators, but I'd need 15 of those to give steps of 1 degree. Is there an easier way to convert from analogue voltage to some sort of signal I could make use of? Thanks | |
Hi Roboticmisinfo, Normally I would go for an UAA170 or even an IR2433 but both chips are obsolete and there aren't any replacements for those which means that you're stuck with a couple of cascaded LM3914's. http://www.national.com/pf/LM/LM3914.html on1aag. | |
Yes of course, thanks for that. I have plenty of those actually. Cheers, Mike | |
| a or d, converter |
| USB - TTL Converter | samltd | Electronic Projects Design/Ideas/Reviews | 5 | 7th July 2006 10:46 PM |
| Monitor Converter: NTSC/PAL to VGA/SVGA scan converter | NOSREME | Electronic Projects Design/Ideas/Reviews | 0 | 21st June 2005 03:46 AM |
| Cuk converter PWM controllers? | Schneibster | Electronic Projects Design/Ideas/Reviews | 30 | 2nd May 2005 10:04 AM |
| FM Converter circuit | VictorPS | Electronic Projects Design/Ideas/Reviews | 3 | 25th November 2004 08:18 AM |
| Low frequency F:V converter | BigM | Electronic Projects Design/Ideas/Reviews | 3 | 26th May 2004 05:54 AM |
