Old 16th March 2007, 09:34 AM   (permalink)
Default 240v - 5vdc ultra low power
what im putting together is a 2.4ghz wireless transmitter/reciever using these units
http://www.jaycar.com.au/productResu...Min=&priceMax=
these guys only need 55mA at 5v and i cant really see the point in paying $15 each for a pair of plug in power supplies that can supply 1 amp
what i want to know is what would be the cheapest way to make a pair of power supplies able to deliver 100mA at 5v the output need not be very clean as it will be going through a +5v regulator ic
Scolly is offline
Old 16th March 2007, 02:21 PM   (permalink)
How about a non engineering solution.
If you do not intend to go into production, you should be able to get the wall warts at a local second-hand/thrift-store. I pay between 25 and 50 cents each.
Unless you are using low dropout regulators you should look for a 9V PS. 7.5V can work, 12V can overheat the regulators. YMMV
3v0 is offline
Old 16th March 2007, 02:49 PM   (permalink)
55mA is hardly ultra low power! If you needed 1uA to 1ma, a shunt regulator would be a good fit.
like 3v0 points out, a second hand or surplus wall wart is your best bet for cheap power
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline
Old 16th March 2007, 03:58 PM   (permalink)
Agreed, there's little to no chance you could build your own power supply for less than the cost of a cheap wallwart. If you tried to build a transformer-based supply you'd just be doing exactly what the wallwart does, and if you tried to build a switching supply you'd end up doing a ton of work. And either way, the components would surely cost more than a wallwart, not even counting the time and effort involved.
EEgeek.net
evandude is offline
Old 17th March 2007, 06:24 AM   (permalink)
WHY NOT USE A CELL CHARGER LIKE NOKIA TYPE. IT CAN GIVE 5v dC AT atlest 200mA
Regards,
Sarma.
mvs sarma is offline
Old 17th March 2007, 06:40 PM   (permalink)
Cell phone chargers are a real steel nowdays. A lot of them are switchers so are both very small and relatively high current, and since cell phones are upgraded as frequently as they are now, always in high supply at thrift shops or surplus stores.
straight answer, har har."
Sceadwian is offline
Old 17th March 2007, 07:00 PM   (permalink)
Lots of them aren't real switchers though because they aren't regulated; they basically crappy wallwarts running at a higher frequency and the ripple is probably terrible. I've opened one up once and it was just a transistor oscillator on the mains side with a rectifier, small filtering capacitor and resistor (to provide a minimum load) on the secondary side. The primary and secondary sides were on separate little PCBs and there was no feedback whatsoever. Even though it was rated at 5V the output measured about 8V off load.
Screen name: Aloone_Jonez
Hero999 is online now
Old 17th March 2007, 07:13 PM   (permalink)
YES, I TOO HAVE SEEN SUCH ITEMS. Not every items suits our requirement. We have to check the voltage on opencircuit and then adopt selected items.
Regards,
Sarma.
Good Electronic Supply's Sites, Everyone Come On In! :P Electric Rain General Electronics Chat 44 27th August 2007 11:05 PM
Need help testing AC/DC power supplies wasman Electronic Projects Design/Ideas/Reviews 3 25th July 2003 03:56 AM
help with my project 5vdc signal to control(interrupt)power vanko Electronic Projects Design/Ideas/Reviews 0 25th June 2003 01:23 AM
interesting thing-other types of electric power bogdanfirst Electronic Projects Design/Ideas/Reviews 4 16th March 2003 07:08 PM
power supply timers JEBB General Electronics Chat 10 25th January 2003 06:37 PM
