Old 11th March 2007, 06:32 PM   (permalink)
Default L293D mis-behaving
Need a little help on the behavior of an L293D h-bridge. It's to be used for a small robot. 2 channel variable PWM provided by a PIC12F509 in increments of 1% duty cycle @ 200HZ.
On the L293D when i apply 5vdc to Pin 2 (input-1) i get full voltage at Pin 3 (motor-1). This happens regardless of the state of the PWM input Pin 1 (Inhibit-1).
I have even physically removed the PIC from the circuit.
Could i have cooked L293D?
Any thoughts?
Thanx,
Zeb
zebby is offline
Old 12th March 2007, 02:33 AM   (permalink)
Default may be...
may be is fryed, but you can figure it out testing it , now, max. input voltage is 7 volts, I guess you did not over pass that? now, what did you connect to the output? you have 600 mili amps... and the enable is high right? I mean a secure high level not disconnected, you can connect it to 5 volts direct or to the enabling source...
try the table with 5 volts and find if is dead or not...
in enable out
H H H
L H L
H L Z
L L Z
jemch72 is offline
Old 12th March 2007, 02:34 AM   (permalink)
The absolute max peak output current of an L293D is only 1.2A. The motor draws a very high current when it starts and when it is stalled. The over-current quickly melts an output transistor so it is on all the time.
audioguru is offline
Old 12th March 2007, 02:39 AM   (permalink)
Default the input...
what about the input from the pic? are you sure it is 200 hz pulses , did you see it whit oscilloscope or scope meter? or measure it with meter?
jemch72 is offline
Old 12th March 2007, 06:56 AM   (permalink)
Default L293D a cheap fix
All,
Thanks for the thoughts and replies!!!
As it turns out a little thoughtfull time spent with an O-scope / DVM, (did i mention the cold beer) and who can tell what might happen.
Two (on each side) 10k pulldown resistors fixed the problem.
I tied input-1 and input-2 to gnd with 10k pulldowns
Applied the PWM signal to Chip-Inhibit-1
no voltage on motor output
Applied +5 to input-1 and the appropriate voltage level apeared on the motor output
Decreased duty cycle to 0% and voltage followed for both fwd and reverse polarity on the motor output
Moral of the story "No floating PINS"
Thanks for the help!!
Regards,
Zeb
zebby is offline
Old 12th March 2007, 02:32 PM   (permalink)
Default high z
Great, yes, high impedance give you that kind of problem, as I said before, a secure level, 0 or 1 , but secure...not high Z...
jemch72 is offline
Old 12th March 2007, 02:49 PM   (permalink)
Any thoughts?
Thanx,
Zeb
it is fried, search no more. i had the exact same problem.
those litle motors in toy cars tend to drain a lot more current that you would execpt a motor of this size would.... i overcame this by providing very good heatsinking and ventilation..
Ibrahim Kamal
check my electronics and robotics page: http://www.ikalogic.com/
ikalogic is offline
Old 12th March 2007, 07:51 PM   (permalink)
Are you talking about the continious current?
I haven't looked at the datasheet but it's highly likely it can withstant a surge of at least 10 times that value for 50mS; it depends on the safe operating area of the transistor.
Screen name: Aloone_Jonez
Hero999 is offline
Old 12th March 2007, 09:56 PM   (permalink)
The L293D is made for driving tiny low power motors.
Its max continuous current is 600mA.
Its max peak current (for only 100us non-repetitive) is only 1.2A.
Old 12th March 2007, 10:06 PM   (permalink)
That's pretty poor, I can't think of any motors that won't take any less than a 5A surge whewn starting up. What use is an IC that can only take 1.2A?
Hero999 is offline
Old 13th March 2007, 01:49 AM   (permalink)
Hero, 50+% of the motors I own aren't capable of drawing 1.2AMPS stalled. Several of them would actually burst into flames if that much current was going through them even for a few ms's
straight answer, har har."
Sceadwian is offline
need help on schematic of l293d santosh_embedded Robotics Chat 6 23rd September 2006 12:31 PM
L293D H-Bridge: Is it effective to run a small DC motor in a model rancid rock Electronic Projects Design/Ideas/Reviews 14 6th July 2006 09:03 PM
differences/advantages/dsadvantages between the L293D and the H-bridge??? please help rancid rock Electronic Projects Design/Ideas/Reviews 9 16th June 2006 11:41 PM
Using the L293D to drive large motors Bondfire Robotics Chat 22 4th December 2004 06:32 PM
PIC + L293D Timmymna Micro Controllers 4 7th June 2004 07:14 PM
