| That IC(Nigel use) is available here on one shop but it is enough coastly... Therefore i am asking some other techniques using low coast components.. Quote:
Easiest solution, use two 9V batteries!. | ||
| The ICL7660 IC is only $.80US at Digikey. They have thousands of them.
| well lucky you but in southern Italy even professionals can wait months for parts
__________________ I AM the exeption that disproves the rule in many ways but the rules still apply (unfortunately) my site:www.simons-photography.com http://rushdenrotaract.org.uk | |
| I didn't know that Italy is a 3rd world country. Don't you have electricity and running water yet?
| hehe electricity yes some places out in the sticks get their water from a suface run mains pipe and some houses just have wells most people buy bottled water to drink anyway. anyhow in many respects I consider southern Italy a third world country especially mentality wise. oh they have electronics fairs but they seem to be top secret I have never seen any advertised
| Even a 555 timer can be used to generate a negitive power supply, both cheap and readily available! ![]() http://sound.westhost.com/project95.htm
| Because you want to supply opamps it seems that you need not a lot of current. Use may a simple square wave oscillator ( like a 4093 or 7414 or 40106 schmitt gate with a resistor in feedback from output of the gate to input and a Cap from the input to GND) to drive a Diode-capacitor ladder voltage pump/doubler/inverter to generate any positive or negative voltage. ![]() http://www.coolcircuit.com/circuit/voltage/vt.GIF | |
| Thanks..... Thanks u HERO999 I think it is the good solution for me cuz it is easy and cheap also and can provide +-12volts... Again Thanks all. Last edited by Ayne; 15th March 2007 at 03:39 PM. | |
| That 555 timer circuit won't produce -12v from +12v, more like ~-10.8V because of the voltage drop of the diodes. It'll still work fine for opamps though. You could use one 555 timer circuit to make 9.4V (a booster circuit) and then another to make -9V. Just thought I'd mention it Blueteeth
__________________ Inconsistency is the key to flexibility! | |
| Yes, but if you read the text it does say that the output is 12V assuming the supply is 13.8V If you only want a really low current supply then use a CMOS 555 with Schottky diodes for a lower voltage drop.
__________________ I AM the exeption that disproves the rule in many ways but the rules still apply (unfortunately) my site:www.simons-photography.com http://rushdenrotaract.org.uk | ||
| I get a lot of my voltage regulators and even transistors from my local TV repairman's junk ben. Junk computer monitors can also be a good source. | |
| hm I did come up with a circuit for making a neg and pos from a single, but never fully tested it just the principle
| single supply DC amplifier | jmantilla | General Electronics Chat | 2 | 29th September 2004 03:05 PM |
| dual power supply | Erwin_Macaraig | Electronic Projects Design/Ideas/Reviews | 2 | 3rd April 2004 02:54 AM |
| dual power supply.... | mugzzzzy | Electronic Projects Design/Ideas/Reviews | 2 | 17th February 2004 07:55 AM |
| Help with dual regulated power supply circuit | xitian | Electronic Projects Design/Ideas/Reviews | 3 | 22nd December 2003 03:00 AM |
| Why op-amp needs a dual supply? | Ravi | General Electronics Chat | 4 | 27th November 2003 11:27 AM |
