Old 10th March 2007, 01:33 PM   (permalink)
Question digital display for magnetic field
Dear Members
I designed a magnetic sensor for navigation purpose(2d-compass). The output of the sensor is in form of analog voltage . I want to add a digital display(for displaying corresponding magnetic field). The sensor output for zero magnetic field is zero volts, so now it must show zero Oersteds in digital display. One more example: if magnetic field is 1 Oe, output voltage is 10V, Now I want 1 Oe digital display instead of 10 V analog output.
If any one has idea about this module please do help me
Thanks and regards
Pratap
PRATAP.KOLLU, Ph.D. Scholar
Division of Materials Science and Engineering,
Engineering building # 1
Chungnam National University(CNU),
220 Gung-dong, Yuseong-gu, Daejeon 305-764,South Korea.
Phone :+82-42-8216227, pratapkollu@yahoo.com
PratapKollu is offline   Reply With Quote
Old 10th March 2007, 02:21 PM   (permalink)
Are micro controllers an option for you?
Spency.
PIC Micro's - Your mind is the limit
PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net
gramo is offline   Reply With Quote
Old 10th March 2007, 02:36 PM   (permalink)
It is possible to buy off the shelf i/c's that have an inbuilt ADC, with inbuilt LCD drivers.
You would have to scale the input voltage from your sensor.
The LCD display I am referring to is a 4 1/2 digit device. ie; 19999
Is this resolution high enough to meet your requirement.?
EricG
Edit: Type ICL 7129 or MAX 1493
ericgibbs is online now   Reply With Quote
Old 11th March 2007, 07:12 AM   (permalink)
I dont know how microcontrollers can do my job, if u have an idea for it please let me know. If possible I will try to implement.
thanks and regards
Pratap
Old 11th March 2007, 07:17 AM   (permalink)
EricG
Thnx u for ur clear answer,
please let me know, if u have any idea of which shelf ic with inbuilt ADC and LCD drivers is good for my application
Old 11th March 2007, 07:45 AM   (permalink)
These devices are 4 1/2 Analog to Digital Convertors with inbuilt LCD driver.
As my earlier post the ICL 7129 can display 00000 thru 19999.
Hope this helps
EricG
Old 11th March 2007, 08:16 AM   (permalink)
Microcontrollers with LCD drivers built-in are sort of oddball parts. There are 100x more devices which don't use that feature. Rather, you get an LCD with an on-board controller which has a lot more versatility. You can display any sort of alphanumeric data (not just one 4 1/2 digit & "-") and you can get multiline or even graphical ones. Might cost $5-$50, electronic surplus catalogs always have quite a bundle of them. The microcontroller talks to the controller by just putting data on the pins, no special hardware feature is needed or even helpful.
Since you want to use this for "navigation", a more versatile LCD sounds appropriate! You can read the magnetic field in the X and Y directions and calculate heading from the ratio. You can also display the field strength and a letter heading (NW, SE, etc).
Oznog is offline   Reply With Quote
Old 13th March 2007, 01:19 AM   (permalink)
Thumbs up
Dear Oznog
You got my work right, I developed a 2d compass for navigational purpose. You mentioned that "You can read the magnetic field in the X and Y directions and calculate heading from the ratio. You can also display the field strength and a letter heading (NW, SE, etc)."
Exactly this is what I want to display, How can I do it, can you please explain me detail.
I would be very thankful to you for your clarification
Thanks and Regards
Pratap
Problem with LCD code? spondootre Micro Controllers 15 29th April 2008 09:15 AM
The Oscilloscope ElectroMaster Electronic Theory 12 3rd February 2008 01:45 PM
Magnets and Electromagnets ElectroMaster Electronic Theory 11 27th November 2007 02:31 PM
microchip application A590 /display is ok now prosound90 Micro Controllers 20 18th November 2006 09:44 PM
digital display jaravind Electronic Projects Design/Ideas/Reviews 3 30th August 2004 01:50 PM
