Old 8th March 2007, 10:20 PM   (permalink)
Default FSK schmatic
hi all
can any body have idea about electronics used in FSK (frequency shift keying ) that used to transmit digital data
BR
khgsm2007 is offline
Old 9th March 2007, 12:30 AM   (permalink)
I am sure that there are many ideas, what do you want to do?
Russlk is offline
Old 9th March 2007, 12:50 AM   (permalink)
The easiest way I can think of to do FSK is to use a varactor diode in the tuneing stage of an oscillator
straight answer, har har."
Sceadwian is offline
Old 10th March 2007, 10:46 AM   (permalink)
Default fsk
hi all
I just want to know how to send digital data let's say "1Byte" and how to rescieve it using FSK way any schematic for fsk transmitter and resciever will be helpfull
Thanx alot for ur concern
BR
Old 10th March 2007, 10:53 AM   (permalink)
How about using a FSK RF transceiver?
http://secure.oatleyelectronics.com/...roducts_id=388
It costs 33 aussie dollars, and is a great piece of kit. Best of all it allows 2-way data transfer
Spency.
PIC Micro's - Your mind is the limit
PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net
gramo is offline
Old 10th March 2007, 10:54 AM   (permalink)
For more info on the device, have a read of the datasheet, it sums it up quite well
Spency.
gramo is offline
Old 10th March 2007, 07:52 PM   (permalink)
hi again
thank u very much every one , actually ur links & info are very helpfull
But i have remote car switch , iam trying to understand the way it operates, It uses HT12E as digital data Encoder & one transistor as transmitter
is that FSK technique , if so how the transmitted data rescieved & decoded.
any help will be appreciated
Thanx in advance
BR
Old 10th March 2007, 11:57 PM   (permalink)
Click here too have a look on Wiki
Frequency-shift keying is a form of frequency modulation in which the modulating signal shifts the output frequency between predetermined values.
This is how the data is encoded;
Spency.
gramo is offline
Old 11th March 2007, 12:11 AM   (permalink)
Originally Posted by khgsm2007
hi again
Thanx in advance
BR
Its hard to say from your description. My first guess is that your remote uses PPM (pulse position modulation) which is a simple form of AM where the encoding chip output is turning the transistor oscillator on and off according to a serial string of bits. This is quite common in North America for garage door opening remotes, for example. If the device uses FM, then the single transistor would still be an oscillator but its frequency may be easily shifted using a varactor diode on its tank circuit fed from a digital serial string of bits from the encoder. Hard to know unless you can spot a varactor diode near the transistor.
RadioRon
RadioRon is offline
Old 11th March 2007, 04:06 AM   (permalink)
Remember using a modem on a telephone line to access the internet?
An old modem used FSK between two or more audio frequencies.
My first modem was 14.4kB/sec and I could hear it alternate between two frequencies. A 56k modem sounds like a lot of noise.
audioguru is offline
Old 11th March 2007, 09:17 AM   (permalink)
Hi all
here is arough schematic for that small transmitter
BR
Old 12th March 2007, 04:54 AM   (permalink)
That's about the roughest schematic I've ever seen here on the boards, but damned if it isn't good enough. I would say that based on this, you have a pulse transmitter which is where the RF carrier is turned on and off according to a sequence from the encoder chip. The fact that the encoder controls the DC flow throught the transistor emitter is the best clue showing the encoder is turning the oscillator on and off.
RadioRon
RadioRon is offline
Old 12th March 2007, 04:58 AM   (permalink)
My first modem was using the old Bell103 tone standard at 300 baud. At about that same time, I learned about RTTY on HF radio using audio FSK. A different signalling standard, but the same general idea.
If you think about it, the 56K modem has to be very spectrum efficient to send so much data on a land line. What you hear is indeed very spectrum efficient since it sounds as if it is filling the entire "audio" spectrum with an equal distribution of energy, which is the definition of white noise.
RadioRon
RadioRon is offline
Garage door hacker schmatic cyberquest Electronic Projects Design/Ideas/Reviews 5 21st June 2004 02:25 PM
