| | #16 |
You don't need a coil to drive a high capacitance piezo, you need a bridge amplifier made with two complimentary pairs of emitter-followers to supply the high charging and discharging currents.
| | #17 |
Okay, I think I will have room for that. Since distortion won't be a factor, can I use a single emitter-follower stage but with really high gain or will that cause a new problem?
| | #18 |
The piezo transducer needs to be driven push-pull. They have a max signal voltage of 24V so a bridge driver could be used with a 12V supply to get about 21V p-p output like this:
| | #19 |
Are there 24 Volts between the "+" symbol and ground or is it like a charge pump situation where I can use 12V? I can can probably start testing this with my 40kHz transducers. In the meantime, I'll just order a circuit off ebay, I can't find a single transducer with the right transfer function.
| | #20 |
My circuit has the transducer in a bridge. The bridge nearly doubles the voltage across the transducer. Use a 12V supply because the Cmos IC has 18V max.
| | #21 |
And what is the OP-Amp IC used in that circuit?
| | #22 | |
| | #23 | |
| | #24 |
Also a coil in parallel can increase the power factor and therefore the efficeincy by effectively recycling the wasted capacitve current.
| | #25 |
One time I had a 240VAC fan that wouldn't run on my 120VAC mains. So I tuned it to my mains frequency with a capacitor in series and it ran fine. It developed about 190VAC. I have never tried "tuning" a piezo transducer with a coil in series to increase its power. A coil in parallel would not allow the piezo transducer to draw much current because then it would be in a high impedance tuned circuit, wouldn't it?
| | #26 |
Sounds like this coil is worth looking into then. Is the voltage-doubling still likely to work the same after the circuit is tuned?
| | #27 |
If the AC source impedance is very low and the resistance of the coil is also very low then the coil in series with a capacitor will be a very low impedance at resonance and a very high current will flow in them.
| | #28 |
I have a water-powered ultrasonic transducer in my yard: the sprinkler system. Very loud high pitched hissss while the air is being flushed out. Advantage is that if they don't respect the sound they'll respect the water.
| | #29 | ||
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. Last edited by Hero999; 12th March 2007 at 10:13 PM. | |||
| | #30 |
You need to measure the reactance of the piezo at the output frequency and put a series reactance to counteract this, forming a low impedance load. This could result in a high output, an overloaded driver, or a shattered piezo. | |
| buzzer or transducer, dog, finding, piezo, stopping |
