Old 1st March 2007, 05:06 PM   #1
Exclamation request circuit for rpr-220 photoeye
The circuits I have tried have only yeilded a output voltage change from .2V to .5V Any help would be appreciated. I am attaching the circuit that I have tried to use and also the data sheet for the sensor that I am using.
yeild is offline
Old 1st March 2007, 06:43 PM   #2
hi yeild,
Looked at the spec and cct diagram, from what I can tell the change will
be small.
How are testing it to get the voltage change you posted ?
All I could find is a 'test cct'. Is this the way you are testing?
EricG
ericgibbs is offline
Old 1st March 2007, 06:55 PM   #3
Hi Eric,
The test circuit pdf is how I am currently testing it. I will be hooking the Vout signal on the schematic to a input on a 8051 microcontroller.
yeild is offline
Old 1st March 2007, 08:03 PM   #4
I don't see anything wrong with the test schematic. Your drive LED bias current is fine. The collector load is fairly high, so you shouldn't have a gain problem. It should switch between 0 and 5 volts. You may have these problems:
- incorrect wiring of components
- too much light entering the sensor at all times. Try blocking all light from the sensor to see if the transistor will then switch off.
RadioRon
RadioRon is offline
Old 1st March 2007, 08:05 PM   #5
Thanks RadioRon
yeild is offline
circuit, photoeye, request, rpr220
Question about HT 8870 in the TELESWITCH circuit !?! zambalik General Electronics Chat 11 6th September 2007 01:11 PM
On-time delay circuit using LM555 mozikluv Electronic Projects Design/Ideas/Reviews 9 24th October 2003 02:45 AM
555 Monostable 2 second output circuit Help Turbo Boss Electronic Projects Design/Ideas/Reviews 2 3rd August 2003 06:41 PM
close a circuit by 0v switch lazynok Electronic Projects Design/Ideas/Reviews 5 10th June 2003 10:42 AM
How can I test this circuit??? thebigbasicq General Electronics Chat 5 22nd May 2003 11:54 PM
