Old 28th February 2007, 01:43 PM   (permalink)
Default Picture in Picture circuit
Hello guys.
We are two students that are doing a project*. We have posted a few posts here earlier, and got a lot of help.
Now we are almost done with the circuit, and wondering if some of you can have a look at it and give us some feedback and/or comments.
We have also a few questions about some pins on the pvp9390 (picture in picture IC.)
Pin 6, SEL - Fast blanking output for PIP, black screen out? cvbs?
Pin 38, INTR - Interrupt output
Pin 41, VSP - Vertical sync for parent channel
Pin 42, HSP - Horizontal sync for parent channel
this is input signals, The camera we are using gives out CVBS, does this signal contain the V/H sync signal?
I know, there are alot of questions
Thanks for any feedback!
* The project it to connect two cameras and look at them at one tv screen.
Like this
I`m also adding the PVP9390 datasheet if any of you want to see it (1.4 MB) HERE the pin description are on page 91
NB: I also added the schamatic for the circuit, it`s in eagle, rename the *.asc to *.sch if you wanna look at it..
jdahl is offline   Reply With Quote
Old 9th March 2007, 01:39 PM   (permalink)
No one got any input? We are really struggling with the HSP and the VSP. Hope someone can help us out.
furyfax is offline   Reply With Quote
Old 9th March 2007, 01:59 PM   (permalink)
You use a sync-seperator to seperate the sync signals from the composite video - you can do it easily with discrete components, or there are some very simple to use IC ones (which is probably a better idea).
Old 9th March 2007, 02:15 PM   (permalink)
This is what I thought, but we constantly have 2 CVBS signal which go into this chip, therefore I don't know wich signal to get the sync from? Any idea ?
Old 9th March 2007, 02:34 PM   (permalink)
Your post above says 'SYNC FOR PARENT CHANNEL', so presumably it's the main one.
Old 9th March 2007, 02:36 PM   (permalink)
Hmm.. I guess we'll just have to try a signal.. We don't have a "main" signal. They're both equal to us, if you know what i mean..
Old 9th March 2007, 02:41 PM   (permalink)
It's called 'Picture IN Picture', so the main one is the background picture that the other is inserted into.
Old 9th March 2007, 02:58 PM   (permalink)
My mistake, I was a bit confused. We're using a microcontroller to send commands to the PiP circuit, at first I thought this would influence what picture is main, but it shouldn't have anything to say.
Any IC you would recommend for extraction of the sync ?
Old 9th March 2007, 03:37 PM   (permalink)
Check out the Elantec devices at http://www.intersil.com/products/pt/...able_10396.asp
Old 12th March 2007, 09:52 AM   (permalink)
Thanks for all help so far Nigel, we really appreciate it.
Do you have any idea how to connect pin 6 "SEL". It says in the datasheet that it's "OBL = obligatory; connect as described in circuit diagram" and it`s short description is "Fast blanking output for PIP"
If you look at page 97 in the datasheet, there's not much help in the circuit diagram.
Old 12th March 2007, 10:10 AM   (permalink)
Presumably it blanks off the main source in order to insert the PIP information?.
Old 12th March 2007, 10:22 AM   (permalink)
I'm uncertain if we need this function, but it says that it's obligatory. Any ide how to connect this?
Old 12th March 2007, 10:43 AM   (permalink)
It connects to some other part of your circuit, the PIP chip is only a small part of the complete design - I would imagine it connects to the decoder IC, the fast blanking input for teletext insertion?, which is where the RGB from the PIP chip enters as well (the teletext RGB input).
I need help in designing a circuit chefach Electronic Projects Design/Ideas/Reviews 13 27th September 2007 11:14 AM
I need help analyzing this circuit. dar2525 General Electronics Chat 9 29th June 2005 01:00 PM
HELP! a digital signal to close a circuit fireismyflag Electronic Projects Design/Ideas/Reviews 2 22nd March 2004 10:45 PM
start/stop watch circuit bd13 Electronic Projects Design/Ideas/Reviews 2 21st March 2004 03:06 AM
Circuit functioning very strange. Why? Cyclone Electronic Projects Design/Ideas/Reviews 12 4th November 2003 12:30 AM
