Old 27th February 2007, 07:50 PM   (permalink)
Question Heater Electronic Thermostat
Hi, friends! I intend to build a simplest 110 VAC electronic controlated heater to use in my aquarium. I would like do make it at the most simple (and sheap) possible, therin a opted to use a thermistor as themosensor and SCR and Triac as charge switches, and wich control circuit could work not using DC Power but directly AC power. Can someone help me? Thanks a lot. (P.S.: I ask you to excuse my "not so good' English, I'm braziliam...)
SiriBrazil is offline
Old 27th February 2007, 07:54 PM   (permalink)
It would be cheaper to purchase one at a store than it would be to build one, and it is not a good learning excercise for electronics.
straight answer, har har."
Sceadwian is offline
Old 27th February 2007, 09:26 PM   (permalink)
High voltage and water don't mix well. This is something best left to a store bought unit. Since you are asking for help, I'm presuming you don't have the knowledge to keep the water away from the electronics. I hate getting shocked, so mostly work in DC. Really dread working on stuff plugged into the wall. Good luck, and be careful.
HarveyH42 is offline
Old 28th February 2007, 12:58 AM   (permalink)
A GFI (Ground Fault Interrupt) is a must for all aquarium equipment scratch built or purchased.
I agree with the above posters.
Since you intend to duplicate what you can already buy then just buy it.
3v0 is online now
Old 28th February 2007, 01:02 AM   (permalink)
I just got a casual shock from 110 yesterday, and that was from dry skin contact. I spent 5 minutes swearing I'd never go near line voltage again. After that 5 minutes it faded but you get my meaning =)
Old 28th February 2007, 08:07 AM   (permalink)
hi siri,
Buy a ready made/shop water heater.
The design and construction of a home made heater wouldn't be the problem.
The problems/risks start when you try to ensure safety against electrical hazards, today and long term.
Have you got all the equipment required to carry out the necessary insulation testing.
Will the materials you using for sealing, for example, be adequate.etc
Also follow 3v0's advice, always fit a RCCB, especially where water or outdoor electrics are concerned.
I know that we must appear downbeat, but you did ask for our experienced advice
Eric
ericgibbs is offline
Old 28th February 2007, 09:50 AM   (permalink)
If I were to build an aquarium heater system I would start with off the shelf heaters. Use 2 small ones per tank. That way if one fails you sill have the other. Set the temperature setting to just above what you will need.
Then I would build a controller that would read the tank temperature with at least 2 probes. Redundancy is a good thing. I would use relays to turn then heater(s) on as needed.
You could write code that would do daily or season temperature cycles as required by the fish. Maybe a button on the controller that would generate the temperature profile that would cause the fish to mate.
Use a RS232 or USB port to download temperature profiles to the controller.
Add an addition relay to control the lights. Add a sensor to ensure the air pumps and filters are working.
Add a 4 line LCD display to show the current temp, Max and Min for the last 24 hours. Other info as needed
Add an audible alarm to signal problems. Have the controller call you cell phone if things went south.
What you can do is nearly endless. What you suggest is not worth the effort.
3v0 is online now
Old 28th February 2007, 09:54 PM   (permalink)
Use a small linear poer supply as the DC source of this circuit.
Screen name: Aloone_Jonez
Hero999 is offline
Old 1st March 2007, 06:27 AM   (permalink)
Arrow
Thank you all, guys, for your answering and worrying. I'm even that water and high voltage is not a good combination to play with, and I promise I will be careful with this. But, once dealing about sink heater, it's unavoideble... I know too so that using DC, and rellays as switch, it is more simple, safe and apropriated (and was already decided for this way) but, quite so, my problem (doubt) still stays: how to make a thermostat, that uses a thermistor as a sensor, work directly in a 110 VAC, without a properly DC power source device?
Thank you too, Mr. 3vO, for your detaileds and finest concernings, but I'm afraid that they could be a bit expensive to me now (by the way, I did not undestand very well , I'm sorry, what means your last paragraph.
Tank you too, Mr. Ericgibs, I have a basic sink heater already, and all wat I dream with is to adapt in it a thermostat, and this thermostat should work in order to turn the heater charge off when certain temperature was detected inside the tank. And it is irrelevant to me if the thermostat works on or off board, since works. And be sure you are not downbeating me, but instead encouraging.
Anyway, I'm gratefull for you all for your contribution. I apreciated and wil analyse the sugestions (and I hope you, Sceadwian, were better (or more serene, at least...) now, from the shock you got). Forgive me if being boring.
Best Regards
SiriBrazil
Old 2nd March 2007, 11:41 PM   (permalink)
You can use a transformerless power supply but it probably won't be able to supply enough current for the relay coil in my circuit but I'd recommend using a small transformer rectifier and capacitor.
Hero999 is offline
Old 3rd March 2007, 10:37 AM   (permalink)
SiriBrazil,
I would be happy to answer any questions.
3v0 is online now
Old 6th March 2007, 01:36 AM   (permalink)
0k, Hero999,
Thank you for your atemption. I will consider your sugestion. I was trying to avoid DC power suply, but it seam more dificult than I thougth.
Thanks again.
SiriBrazil
Old 7th March 2007, 04:12 PM   (permalink)
Default phone call
3v0,
How would you make a this call your cell phone? If it did call your phone would it give you a series of tones to indicate a problem?
Thanks in advance,
Carz
Carz is offline
Old 7th March 2007, 07:37 PM   (permalink)
Originally Posted by Carz
3v0,
Thanks in advance,
Carz
It is easy to have a microprocessor dial a phone number. You can do it with a simple relay or DTMF.
Once the connection is made you have several options.
Beep out some code that is meaningful to you.
Record some low quality speech (1 or 2 bit) and have the PIC send it over the phone when needed. Roman Black PicSound
Have the controller signal a Windows XP PC and have it speak the needed message. How To Configure and Use Text-to-Speech in Windows XP
3v0 is online now
water heater with temperature controller jemilsan Electronic Projects Design/Ideas/Reviews 27 1st March 2007 07:14 AM
100 electronic circuits with ready to copy pcb reyarba Electronic Projects Design/Ideas/Reviews 0 1st November 2006 12:32 AM
controlling an AC heater using PIC ? zika1212 Micro Controllers 4 25th November 2004 03:01 AM
frequency-voltage don't work with electronic ignition. Screech General Electronics Chat 7 16th March 2004 01:29 AM
concerning charecteristics of resistive heater Ramesh Babu Adari Feedback/Comments 0 25th February 2004 02:39 PM
