Old 22nd February 2007, 03:28 AM   (permalink)
Default AT power supply to power Laptop.
My friend's laptop power supply recently fried, but I took the weird Sony plug of the adaptor and swore to jerry-rig a replacement. Now, I have a 200 Watt AT power supply that I pulled from a 486 from way back when, and I'm wondering the following:
The laptop says it takes 16V at 4 Amps.
Checking the voltage between the +12V and -5V lines shows 16.06V on my multimeter.
The -5V output is rated for 0.5A, the +12V at 8A.
Soo...What amperage do I expect from this -5 to +12 setup? Only 500mA?
ArtemisGoldfish is offline
Old 22nd February 2007, 04:14 AM   (permalink)
Yes, only 500mA.
To adapt an old saying: "Chain is only as strong as its weakest link".
JimB is offline
Old 22nd February 2007, 04:37 AM   (permalink)
Would there be some way that I could combine +5V and +12V lines to get a workable voltage? And does the amperage matter so long as it's above the laptop's 4 amp requirement?
Old 22nd February 2007, 08:40 AM   (permalink)
Not with one power supply.
straight answer, har har."
Sceadwian is offline
Old 24th February 2007, 02:07 PM   (permalink)
Have you tried it with 12V?
Screen name: Aloone_Jonez
Hero999 is offline
Old 24th February 2007, 08:47 PM   (permalink)
Hero might have something. I mean what inside a laptop could really need 16 volts? It might just be overhead for the linear regulators. Since you're feeding it regulated 12 volt power, it may work. But I don't know much about the power section of a laptop and it could burn out or cause unintended malfunctions, just had to tack that disclaimer on there in case it blows up when you plug it in =>
Old 2nd March 2007, 05:39 PM   (permalink)
Most likely it will run fine on 12Volts; however the battery may not be fully charged.
ante is offline
Got a new EVBoard How do i supply power to it? cubdh23 Micro Controllers 2 3rd August 2007 10:39 AM
24v DC Power Supply (Help & Information Wanted Urgently) ampthetex Electronic Projects Design/Ideas/Reviews 5 17th November 2006 01:45 PM
Power Supply for a project to be powered within an Auto? hexibot43 General Electronics Chat 16 8th September 2005 03:36 PM
Power Supply Failure Joel Rainville General Electronics Chat 8 24th August 2005 02:42 PM
Low current power supply from stored current. McGuinn Electronic Projects Design/Ideas/Reviews 12 20th January 2004 07:15 AM
