| I need a 95VDC motor to run from regular household current (120v AC) Motor Specs:1 HP, 9.1 AMPS, 4150 RPM, CW Rotation, 25 C Ambient, Open Const 1) I need to know what Bridge Rectifier I should use 2) I need to know what capacitor I should use 3) What kind of speed control can I use? (preferably something inline with the power supply. I had thought maybe a dimmer swith for lights???) I have read enough on it to know #1 & #2 are the items I need. However there are so many choices to choose from so please be specific for a newbie. Thanks for any help!
__________________ JayT Never Say Never! If you can dream it, it can happen! http://jacaldesigns.com | |
| With a motor that size, you wil need a PWM speed controller. Lamp dimmers aren't rated for DC (they latch on, and stop controlling). If you want to do it right, you need to find a transformer with a secondary voltage of 130 volts (center tapped) that is good for about 12 amps - you need the extra capacity for stalled condtions, so the breaker can pop before the transformer smokes. A full-wave rectifier will do - any two stud mount diodes rated 400 volts and 20 amps (lots of capacity) will do. You will need a fairly large filter capacitor. I'd guess on the order of 10,000 microfarads, but someone will probably know better. If the motor doesn't have to reverse, then a simple half bridge circuit will do for the speed control. | |
| Get a 15 Amp variac. ( 0 to 130 Vac range ) Will give full speed control with some loss of torque at lower speeds. Use a 400 Volts 35 Amps full wave bloc rectifier.
__________________ There are more ways to get to Rome. Electricity, Electric clocks, Meters and Trains are great. | |
Now that you are getting me on the right track, where is the best place I can buy this stuff? preferrably online, but doesn't have to be. Thanks for your help
__________________ JayT Never Say Never! If you can dream it, it can happen! http://jacaldesigns.com | ||
| hi, I would support Rodalco suggestion, its nice n easy. If at some future time, you always add some back emf detection to adjust the dc to control the speed/torque. EricG | |
GBJ1510 @$2.21 should be plenty, stud mounts are a: overkill and b) expensive (we use GBJ2506 to dive 20A into a motor) I would recommend a FGH20N6S2 @ @2.34 as a low end part for reliability. You should really find one that has a lower Vce(sat), but it will cost more. SMQ201VSN102MP45S @$4.24 is probably a good one to try for starters... 1000uF 200V 3ARMS. DO NOT GO LOWER IN VOLTAGE OR ARMS Oh, and did I mention to make sure you heat sink the parts really well? Dan | ||
| Thanks CadStarSucks for the Digikey.com info. It looks like the route I will go. The motor originally came off an old treadmill. I still have the electronic circuit board that went with it. I remember some of the sensors had went out a few years ago. I took a picture of the board because I am going to assume what I need is on that board already beings it run off house current when it did work. I am pretty sure the bridge rectifiers are the black things heat sinked to the sides. They are 5 of them. Are they run in Parallel? I am not sure which part is the capacitor though. Is it the white porcelain looking piece? I have a google education on what I have learned so far about electronics so bear with me.
| | (permalink) | ||
__________________ --- The days of the digital watch are numbered. --- | |||
| Thanks kchriste, I hope this will help better. I also added the pic of how I would wire the rectifier and capacitor together. So was I right to assume the rectifiers are the black things heat sinked to the side? (1) Would I parallel wire them? (2) Would I use all 5?
| In your pictures the capacitors are the tall 'can' shaped items with a silver coloured top and a stripe down one side. The heatsinked items are not rectifiers. Rectifiers come in various shapes, but they all have four legs. http://en.wikipedia.org/wiki/Diode_bridge Diode bridge - Wikipedia, the free encyclopedia Last edited by House0Fwax; 21st February 2007 at 02:29 PM. | |
| OK, Here is what I am going to go with (check out attachment) Looking at the picture: (1) What rectifier would I use for the Motor Specs listed. (2) What Capacitor would I use? (3) What Speed Controller can I use? (4) Where would the Speed Controller go? (I labeled 2 spot on the schematic) I will hopefully purchase all the items from Digikey.com After this one gets answered I will leave all you guys alone. I think I should have enough info to make this happen.
I looks to me like you have 2 diodes and 2 SCRs for a phase controlled bridge and a freewheeling diode across the motor. It would make even more sense if you look and found they are all the SCRs with three being used as diodes. For a PWM you would need 6 in that configuration. If they were dual diodes there would only be 4 as there would be 2 for the bridge, an IGBT, and a freewheeling diode. And you would need the capacitor. The "white porcelain looking piece" is an inexpensive power resister use for over current protection. Dan | ||
There is no main capacitor in his piccys. It would be on the order of 1.5"x1.8" not 0.3x0.5". Diodes only have two legs, duals three and bridges four. I will maintain that he has 4 SCRs in a controlled bridge. Dan | ||
Dan | ||
| Project: DC Motor Control (using a single switch) | arijit18 | Electronic Projects | 15 | 28th October 2008 01:59 PM |
| Question about rectifier bridge | wat | Electronic Projects Design/Ideas/Reviews | 14 | 1st December 2005 09:48 AM |
| full-wave bridge rectifier problem | MsStateDawg | Electronic Projects Design/Ideas/Reviews | 12 | 5th January 2004 07:52 PM |
| bridge rectifier | batman | Electronic Projects Design/Ideas/Reviews | 2 | 15th December 2003 05:27 PM |
| Bridge Rectifier Current Rating -- How much is enough? | hamfiles | General Electronics Chat | 6 | 6th August 2003 07:15 AM |
