| Hi, previously I have posted regarding building a wireless USB webcam that send real time images. I was adviced that that wasn't a good idea due to the huge amount of bandwidth needed and also other factors. I have thought it through and I have another idea, a simpler one and a more practical one (I hope). Instead of transmitting real time life images, the webcam only captures a still image and send it to the PC when I click a button. For a start, just a monochrome image will do because it will need less bandwidth. The webcam will then send the data via wireless (radio signal) to the receiver attached to the USB port. The process of the webcam taking a picture, process it and send it to the PC can take about minutes. It doesn't really matter as I am more interested in the mechanics/how it is done compared to the speed. So, can anybody please point me in the direction of how to do it..? I have started by reading the book "USB Complete".. Thanks.. | |
| A book on USB is about as useful to a hobbyist as a lead weight. You need to use a serial to USB converter (which are capable of some fairly high speeds) and a micro controller. There are camera and radio modules out there aplenty that use simple serial protocols that are easy to interface with a micro controller.
Yes, I intended to use micro controller and any other component that is needed. Do you have any link of the camera and radio modules that I can use..? | ||
| Actually, the project uses a Wireless device (2 pairs of transmitter/receiver or 1 pair of transceiver unit) that is able to convert USB signal to radio signal and vice versa. These unit is connected to the USB port and the webcam Here are 2 options of how the wireless device work. The first option is the Wireless device is an active device. When I click a button on my PC, the USB transmitter (attached to the PC) will send a signal to the receiver (attached to the webcam). That signal will turn the webcam on, capture an image, do the necessary convertion (and maybe modulation) and send the data (of the signal) back to the unit attached to the PC. The PC unit will them convert the RF signal into USB signal so that the computer can receive and interpret it. After the webcam capture the image and process it. The second option is the Wireless unit acts as a passive one. It merely transmit the data and sent from the device driver to the webcam and receive the data from webcam to the device driver. Because some delay may be involved due to the travelling of signal, the wireless unit (attached to the PC) need to slow down the execution time of the command so that the 'handshake' between the webcam and the PC is still active and the USB is still connected to the PC (eventhough there are some transmission delay). I personally prefer the second option but I do not know if the option can be implemented. Any thoughts on the idea..? Thanks.. | |
| You'll need to implement the "host" side of a USB interface in order to use a USB webcam. This is a couple times *harder* than building up a normal USB device, which is already something that not very many hobbyists can do. Not impossible, but it is at least a couple thousand lines of code... There may be a couple ASIC parts which can simplify this task, but it is definitely not easy. Doing completely custom hardware is a really bad idea. Personally if I had to do something like this, I'd start with a Linux based computer like a NSLU2 (google for it) or other ARM/Linux based wireless router and make this into a software task. Drivers are already in place, and you might be able to use off-the-shelf software like (http://www.seismo.ethz.ch/linux/webcam.html). | |
| Sparkfun has a wide variety of wireless modules, cheap low end ones that cost just a few bucks, and slightly more expensive ones that offer a lot of features and bandwidth (possibly enough to do slow scan TV) www.sparkfun.com This website sells cmos camera modules that even do object tracking but have the core feature you're looking for, a straight serial image dump. http://www.cs.cmu.edu/~cmucam/home.html Add one wireless module, one cmucam module, and one micro controller, shake briskly =) and have fun hooking it all up and codeing it.
| Thanks for all the feedbacks.. Sceadwian, you make it sound soo easy.. hahaa... Thanks man, will look into the links.. | |
http://www.mouser.com/search/Product...alkey895-VDIP1 Dan | ||
http://www.vinculum.com/documents/fw...1L_FW_VDIF.pdf Trying to handle a real webcam is quite a bit harder. Obviously not having the USB interface as part of this project would make the software part a lot easier. | ||
It does not, however handle "USB RS232 style interfaces" The UART interface is for the microcontroler. There is also a synchronous serial and a parallel interface in it for better through put though PICs could not keep up with the latter. Dan | ||
As for the VNC1L chip, confusing is the key word. From http://www.vinculum.com/documents/fw...1L_FW_VDAP.pdf page 11, it has some commands to interface to a FT232/245/2232 on it's USB port 1. Also, it looks like it can also use a serial USB interface as the command interface - I think... | ||
Here is the IC data sheet. I hate the way they split it as all the pinning info should not be on the firmware spec that you found. Dan | ||
| Thanks alot for all the suggestions and ideas.. Quote:
However, there are several things that I do not understand and need clarification. Uses of VDIP1 If my understanding is correct, by using VDIP1 connected to the USB port, I can control a microcontroller by using USB signal. And if I understand correctly again, by attaching a micro controller to VDIP1 and VDIP1 to a USB device, I can program the microcontroller to control the USB device. Again, if I understand it correctly, by using 2 pairs of VDIP1 and microcontroller (1 pair connected to the USB port of the computer and another pair to the USB device) and by using RF to transfer signal between 2 microcontroller, I can access the USB device remotely (provided it is a mass storage system device).. Well, having said that, I do know that my understanding is not that correct.. so please correct me so that I can understand it better. Controlling of VDIP1 The datasheet says that I can control VDIP1 with UART, parallel FIFO, or SPI. The only thing I know is UART stands for Universal asynchronous receiver/transmitter, SPI is Serial Peripheral Interface, and FIFO is First in first out (i think). I never had any experience using those things or commands or language. I dun actually know what they are and what they do. If I want to interface it to a microcontroller, what microcontroller should I use and how should I control VDIP1, with UART, FIDO or SPI..? (So far, I have only used PIC16F84A before but I am keen on trying new things.) Using it with camera Since it is not possible for me to use VDIP1 with webcam, can I use it with a C328 camera..? C328 is a camera that is able to transfer the image in RS-232 format. Below is the link to the camera. If I cannot use it directly, what is the component that I need to add so that I can interface C328 camera with VDIP1. http://www.sgbotic.com/product_info....6b1b9cbf56888f Thanks for your time and patience.. | ||
| I'm actually pretty confused as to what the VDIP part actually does. In the DS_VNC1L_FW_VDIF.pdf, page 4, first paragraph it mentions something about USB port 1 being able to become the "command monitor" port, but it doesn't mention this anywhere else. Having the data sheet spread across a dozen different files with lots of replicated information is just plain strange. Needing clarification is a polite understatement... There are a couple categories of USB devices: a standard device, a host, a hub, and some new thing they call USB "on-the-go" which is mix of a device and a host. The VDIP part is a USB Host device, and can only talk to USB devices. Your PC is also a USB Host, so your PC and the VDIP part can't talk directly to each other. There are cheap USB->RS232/serial devices which are the easiest way of connecting a uC to a PC. So the data chain in this case (if the VDIP part could talk to a camera) would be: Camera -> USB host chip (i.e. the VNCL1 chip) -> uC -> RF RF -> uC -> USB device interface(*not* a VNCL1) -> computer Although it's easier to just do RF -> uC -> computer (through a RS232 serial port) A UART is typically used for RS232 style data(the serial port on the PC is this type. Look it up - this is common info). PIC's should be able to use any of the interfaces, and it's up to you to decide how much bandwidth / pins you want to use. If you use that camera module, you don't even need to use the VNCL1 parts. It isn't USB, so you don't need to bother with any of this mess. Just get a RS232 RF interface module (http://www.radiotronix.com/ ?) and just hook it up to the computer. <waving hands furiously> | |
| hjames: Thanks alot for the explanation. Really helps.. | |
| Wireless USB webcam | MrNobody | Electronic Projects Design/Ideas/Reviews | 8 | 14th January 2007 12:37 AM |
| Changing a webcam to wireless | MCF | Electronic Projects Design/Ideas/Reviews | 1 | 17th February 2006 09:20 PM |
| Answers for cisco test | faiz | General Electronics Chat | 0 | 13th July 2004 04:06 PM |
