| How would I transfer a number from an up-counter into a shift register? (shift register made from D types). I need the number in a shift register as I do some wierd stuff to it next to compare it with another. I don't know how to use a microcontroller yet, so I cannot use one in this project. | |
| hi ico, Assuming the Up counter has parallel outputs of the 4/8 bits and assuming the Shift register has a parallel load option. If its made up of 'D' type FF's then it has the equivalent, the 'D' inputs. Just connect the outputs from the Counter to the respective input 'D' bits of the Shift register. Generate a clock/para load pulse into the Shift reg to load the Counter into the Shift reg. Is this what you mean ico ? Do you have a drawing of your circuit? EricG Last edited by ericgibbs; 19th February 2007 at 02:23 PM. | |
| Thanks, I think I can do that. Trying it out in croc clips now | |
| dwg? sorry, acronym not understood :s | |
| Got this circuit working now Thanks !!! | |
| How we can do it in Assembly..Help Needed | Ayne | Micro Controllers | 37 | 29th December 2006 06:49 PM |
| Shift register | mstechca | General Electronics Chat | 1 | 19th December 2005 12:45 AM |
| Code not working..help | Electrix | Micro Controllers | 15 | 26th September 2005 12:12 PM |
| Shift Register project... | jrz126 | Electronic Projects Design/Ideas/Reviews | 6 | 16th February 2005 03:39 AM |
| using shift and stage register with controller | waqar | Micro Controllers | 0 | 18th April 2003 07:37 AM |
