Old 19th February 2007, 10:26 AM   (permalink)
Default Test Light For Automotive Installs
Hello Everyone, once again I need your expert knowledge.
I install car audio, and remote starters, and the like. I would like to make a test light the I can hook up to power and ground with some aligator clips, and then probe wires. If it is postive it will turn a red LED on. Or if its GND then it will turn on the Green LED. So far it works, The problem is the LED's both light up once powerd up.
I have a schematic below. I cant figure out how to isolate both led's from the supply circuit, without isolating one from the Probe circuit. Hopefully you understand what im trying to say.
Or maybe im just going about this the wrong way all together. Prehaps I should use transistors to switch them on and off. only I dont really know how to wire them up. Please Help me out.
What is offline
Old 19th February 2007, 10:53 AM   (permalink)
You have shown the isolating diodes the wrong way around, but as the LEDs both light up when you apply power, this must just be a drawing error.
You don't really have a problem because when you use the probe, one LED will go off leaving the correct one illuminated and brighter. Just look on the fact that they are both otherwise on as an indication that the circuit is connected up correctly - like a dual power-on indicator.
I can't believe you would be worried about draing the car battery!
dch222 is offline
Old 19th February 2007, 11:59 AM   (permalink)
hi what,
Attachment, have look.
Use 1.3W Zeners.
Lets know
EricG
ericgibbs is offline
Old 19th February 2007, 12:09 PM   (permalink)
Nice one Eric. Elegant and simple solution.
dch222 is offline
Old 19th February 2007, 12:48 PM   (permalink)
I am not worried about draining the car battery. I just dont want any LED on until I probe a wire. I am already going to use a yellow LED to indicate power. I mean if I wanted them both on, couldnt I have not just left out the diodes? as the LED themselves will go off leaving the correct one illuminated and brighter when probing.
Now I think I have 1w zenor's will those work? Is that really going to solve my issue? So far I have been unable too using my zenor diodes.
What is offline
Old 19th February 2007, 01:05 PM   (permalink)
hi what,
If your zener diodes are 6V8 at 1 Watt, this would suggest that as W=V * I
and transposing I=W/V,,, I= 1/6.8 = 147mAmp.
[Calc your R1 to give the LED the max brightness, without exceeding its rating]
If I didn't think so, I wouldn't have posted it!
It would take you all of 10 minutes bench time to give it a try.
What zeners and how were they connected?
EricG
Old 20th February 2007, 03:48 AM   (permalink)
The Zeners diodes I tried using were 1n4741
And they were connected as to your diagram you posted; except Without that fancy math calculation u just posted for the resistor value
What is offline
Old 20th February 2007, 04:29 AM   (permalink)
!N4741 is an 11 volt zener. It won't work. You need a 6.8V zener, as Eric says. If you want to stick to the same series, use 1N4736.
Ron (aka Rube)
Roff is offline
Old 20th February 2007, 05:36 AM   (permalink)
You don't really need zener diodes. See attached circuit. You can add a resistor (say 1K) in parallel with the LEDs if you want it to be less sensitive to leakage currents.
kchriste is offline
Black light vs Black Light White Oznog General Electronics Chat 4 22nd October 2006 12:17 AM
Light sensor with LED's mcs51mc Electronic Projects Design/Ideas/Reviews 13 7th July 2006 06:34 AM
faulty digital components testing,checking walters General Electronics Chat 5 22nd August 2005 08:10 PM
LED Test light baintx Electronic Projects Design/Ideas/Reviews 7 17th January 2005 09:42 AM
Answers for cisco test faiz General Electronics Chat 0 13th July 2004 04:06 PM
