Old 15th February 2007, 12:34 PM   (permalink)
Default adc/dac interfacing with pic microcontroller
hello
this is my first thread here and i really need ur help in this project
i need to make an interfacing circuit which includes a mic and adc/dac and pic 16f877a microcontroller and speaker and the circuit or microcontroller is required to store 5 audio samples and then send them to dac and then to speaker in more simple way i need to make a circuit that acts like a recoder as u speak into a mic then adc sends the samples to microcontroller which is required to store 5 samples then send them to dac and from dac to speaker where i can hear the sound again so can anyone help me with a circuit diagram or pic program coz i am not so good in microcontrollers programming and thanks in advance
bebo670 is offline
Old 15th February 2007, 04:22 PM   (permalink)
Input: you'll need a lowpass filter (with cutoff of about 3400hz, hope I got that correct), a switch (for sample & hold) to be controlled by control signals from your micro. A fast ADC might eliminate the need of the SHC stage.
The rate at which the micro initiates the ON/OFF switching determines your sample rate. You'll need an ADC between micro and input stage. Of course.
By the way, why just 5 samples. Have you considered the quality of your output?
Finally a DAC connected to the serial output of your micro. You'll need an RC filtering scheme at the output to smoothen the staircase shape of your output and approximate it to a sinuisoidal waveform, which is what our voices sound more like. This is just the electronics.
There are a lot of example programs to help you along. You can try out Nigel's page. Lots of stuff there.
Everybody can but not everybody will.
aibelectronics is offline
Old 15th February 2007, 04:30 PM   (permalink)
The PIC 16F877A he suggested already has an internal 10 bit A2D, which you can configure to use as 8 bit - which would be a good idea for this application.
I think he means 5 sequences of samples?, so 5 seperate sound clips.
A simple R2R D2A ladder is all you need, followed by a low-pass filter.
There's a tutorial about using the A2D, but the memory storage (as in the other similar thread) is the BIG problem!.
Old 16th February 2007, 12:47 AM   (permalink)
thanks alot guys for ur help i really appreciate it and i will do as u suggested and see what happens and hope everything works fine thanks again guys
bebo670 is offline
help required urgent...microcontroller burning project +keypad interfacing kalprajesh Micro Controllers 0 17th October 2006 06:30 AM
interfacing microcontroller with UART(8250) jam_mafia Micro Controllers 23 26th February 2006 04:20 AM
Newcomers, please read! (PIC regarded) Upd. 0xD Jay.slovak Micro Controllers 0 17th April 2005 02:05 PM
Interfacing a microcontroller with a modem matt_d82 General Electronics Chat 3 21st March 2004 03:43 AM
interfacing Atmel Microcontroller AT89C51 with LM75 umar abdul sattar Micro Controllers 0 28th June 2003 06:27 AM
