| Hi, I am working on a project at home, a Hot Wire Foam Cutter! It calls for a power supply and a schematic is given from hobbycnc.com. The power supply is going to supply 24volts and about 4-8amps to a circuit card. This circuit card in turn will give electricity to a wire which will be used to cut foam. http://www.hobbycnc.com/downloads/powersupply.zip It's the BOW POWER CIRCUIT.pdf I purchased: one 24 V.C.T. @ 5 AMP POWER TRANSFORMER (Model TX-245 from allelectronics.com). one 35 AMP 600 PIV BRIDGE RECTIFIER (Model FWB-356 from allelectronics.com) one Capacitor 40V 10000uF (Mouser P/N 75-36DE103G040AM2A from Mouser.com). Bleed Resistors set up as 3pcs 5.6K 1/2W in parallel. I hooked it all up and nothing blew up, but when I checked the voltage (at TB7) and I get 37.5 Volts. Can you explain to me what is happening and what is going on? | |
| Yes your 24VAC is an RMS(root mean square) measurement. The peak voltage of an AC sine wave is SQRT(2)*Vrms. In your case Code: 24VAC * SQRT(2) = 24VAC * 1.414 = 33.93 Volts | |
| Does anyone know why you need DC to cut foam? BTW, you won't get 37.5V when you connect it to your Nichrome wire. Last edited by Roff; 12th February 2007 at 11:04 PM. | |
| Thanks for the quick reply! I checked my AC voltage and it hovers around 121VAC. This transforms the voltage to 28.1VAC. Then multipling 28.1*sqrt(2) = 39.7334VDC then accounting for the voltage loss in the Bridge Recitifer 39.73 - 1.4 = 38.3VDC which is pretty close to what I am getting, but why am I getting 28 Volts out of my transformer when it says that it is a 24 Volt transformer? | |
| I think transformers are generally rated at full load. That would account for some, or maybe all, of the difference. | |
| So, you are saying that if I hook up my nichrome wire across TB7 that should drop the voltage? | |
| Hi jbchrist Quote:
at full load. The difference between no load and full load will be greater with low power transformers, so don't be surprised if a 24 volts 5 VA transformer gives you an output voltage between 36 and 48 volts. on1aag. | ||
If you really want 24 volts, get rid of the rectifier and the capacitor, and connect your fuse directly to the secondary of the transformer. I see no reason for DC in a foam cutter. Last edited by Roff; 13th February 2007 at 12:50 AM. | ||
| The bridge rectifier and capacitor aren't even needed. You can run a foam cutter straight from the transformer, why someone would even think of running a foam cutter off DC if they had AC already I don't know.
| The reason for the rectifier and the capacitor could be higher output power. If you increase the effective voltage by 41 %, the effective current will also increase by 41 %, doubling the power. A 24 volts, 6 amps transformer is easy to find, a 36 volts, 4 amps transformer might not be readely available in local shops. on1aag. | |
| Which gets hotter, the nichrome wire or the transformer?
| I've never heard of a rectifier or capacitor setup that actually increased output power... The diodes are going to introduce loss and so is the capacitor, how does that increase power? It's heating element not a DC load where voltage regulation matters.
| The reason I am using DC in the Foam cutter is the software and the circuit card will control the heat automatically from the software. That is why is needs to be converted to DC. | |
| Good Electronic Supply's Sites, Everyone Come On In! :P | Electric Rain | General Electronics Chat | 44 | 28th August 2007 12:06 AM |
| Got a new EVBoard How do i supply power to it? | cubdh23 | Micro Controllers | 2 | 3rd August 2007 10:39 AM |
| 24v DC Power Supply (Help & Information Wanted Urgently) | ampthetex | Electronic Projects Design/Ideas/Reviews | 5 | 17th November 2006 01:45 PM |
| PC Power Supply Problems | brentonw2004 | Electronic Projects Design/Ideas/Reviews | 3 | 29th March 2005 12:01 PM |
| Low current power supply from stored current. | McGuinn | Electronic Projects Design/Ideas/Reviews | 12 | 20th January 2004 07:15 AM |
