| I found in two or three of them a common symptom. Every time I replaced the main Fuse it blows. Is this a common problem ? Please help me by your experience and if possible lead me to resources to enrich my practical knowledge in this field
__________________ Its what your friend in Your mind, what you in your friends mind | |
What motor ratings are you working with? Various could 0.1-1HP or 1-10HP. At my job we work with 3HP running right off the rectified line, so in that case there is no power supply in that sense, only a motor control. D. Last edited by cadstarsucks; 13th February 2007 at 01:12 AM. | ||
Sorry for not making my problem clear, My problem with PC Power Supplies and not with my VSD's. I'm reading related topics found here in the forum, but still i'm in need for more practical information. thanks again cadstarsucks and sorry for misleading you.
__________________ Its what your friend in Your mind, what you in your friends mind | ||
D. | ||
| Thanks cadstarsucks for your continues interest to help me, and sorry for my broken English. It looks that I知 doing quite systematic since I checked exactly in same sequence (Fuse, Fan, Transistors). But while testing the first two is so simple, the Transistors are making some trouble for me to check. Is it similar to ordinary transistor check procedure?! by considering that the transistor as two diodes or it needs different procedure ? by the way I've got Transistor checker in my multimeter, do it of any use for power transistors ? Thanks for your help
| Check electrolytic capactitors too. These fail under high temperatures when the fan fails.
__________________ There are more ways to get to Rome. Electricity, Electric clocks, Meters and Trains are great. | |
D. | ||
One of the things I found in SMPS is the high number of coils. I do not no how to check wither the coil o.k. or not. Another problem is the Toroidal transformer, why is the transformer is needed while we tailor the wave shape and value we need, (or at least that痴 my idea of SMPS), and again I do not know how to check them. Thanks for all who is trying to help
The only way to check an inductor, other than visual and not open, is to measure the inductance knowing what it is supposed to be. The transformer you is a bit easier, you connect it to a signal generator and see what comes out the other end, but you still need to know what it is supposed to be. D. | ||
| | (permalink) | |||
| Thanks for your patiant on my silly questions, if possible i'd like to keep on questioning, may be every body else participate also. Quote:
Thanks again
__________________ Its what your friend in Your mind, what you in your friends mind | ||||
| | (permalink) | ||
A high voltage diode and capacitor might do the trick. IF there is no PFC you can look at the low side, but I think PC supplies all use universal input power factor correction these days. That would mean a PFC switcher boosting the line to 400V and a regulator switcher driving the outputs, unless they are getting creative. D. | |||
| Using a computer power supply WITHOUT a computer? | grrr_arrghh | General Electronics Chat | 13 | 4th April 2007 01:15 AM |
| Switch Mode Power Supply (SMPS Unit, ATX & non-ATX) | Aasim | Electronic Projects Design/Ideas/Reviews | 4 | 25th March 2005 07:22 AM |
| I need help switch mode power circuit | darkstorm | General Electronics Chat | 1 | 1st March 2005 08:28 AM |
| help needed in switch mode power supply design and anaylsis | mikechamboko | Electronic Projects Design/Ideas/Reviews | 0 | 1st March 2005 07:14 AM |
| power supply for pic - need help.... interference problems! | SnM | Micro Controllers | 28 | 19th October 2004 05:18 PM |
