Hi, Need to construct a LED strobe type flasher unit which flashes 2 pairs of amber/yellow LED's. Ideally needs to run on either 2 x AA batts or 9v cell. Need to flash twice quickly on 1 pair then change to other pair and keep alternating similar to emergency vehicle type but to run a small battery. Can somebody help me? Thanking you in anticipation. Steve | |
If you search the forums for LED strobes, there have been a couple topics on this. Or handy dandy search feature isn't working at the moment though. The double flash will make it harder to do. I simple 555 timer can give you a single alternating flash.
Thanks for quick response. Trouble is am an electrician and have limited electronic knowledge. Will double flash be big problem as need this really?
| how to make this Theres one of the topics I was thinking of. The last response might help you. If you dig around here, theres more I know. I just can't remember the titles. | |
| | #5 | |
What components would I need for this and is a diagram available? Sorry to be a pain! | ||
| | #6 |
There were a couple of discussions about blinking an LED twice then blinking another LED twice, for toy police cars. A circuit used an oscillator driving a CD4017. The 1 and 3 outputs of the CD4017 had diodes to a transistor to blink the 1st LED, then outputs 5 and 7 had diodes to another transistor to blink the 2nd LED. then the 8th output of the CD4017 made it reset. EDIT: The IC is a CD4017.
__________________ Uncle $crooge Last edited by audioguru; 2nd February 2007 at 01:34 AM. | |
| | #7 | |
JB
__________________ Nothing is impossible for the man who doesn't have to do it himself - Weiler's Law | ||
| | #8 |
Use a 4017 IC driven from a 555 IC or eq. to make it receive clock pulses. Put on all 4017 outputs blocking diodes, set the light sequence with additional diodes after the blocking diodes, then drive the output transistors and led's as required.
__________________ There are more ways to get to Rome. Electricity, Electric clocks, Meters and Trains are great. Please don't sent me private messages, I will not answer them. The questions asked can be discussed in the open forums. http://www.youtube.com/user/RODALCO2007 some interesting electrical stuff to watch. | |
| | #9 |
If you make the LED current really high then they will blink as brightly as strobes, maybe even with a bit of smoke. But only one time.
| | #10 |
Hi, ste1070 If you are interested, attached is a simple program using PICAXE that will do exactly what you desire. Programming a PICAXE is probably the simplest of all, using the free Program Editor and a simple three-wire RS232 cable. After you are through programming, simply mount the 8-pin AXE007, two resistors and the two LEDs, plus three AAA cells into your model car and have fun! See also: www.jrhackett.net Hope this helps. AllVol Sorry, the attachment would not download. I've never had that problem before.
__________________ Creationists have a world of evidence Last edited by AllVol; 3rd February 2007 at 02:44 PM. | |
| | #11 |
Let me try that attachment again.
__________________ Creationists have a world of evidence Last edited by AllVol; 4th February 2007 at 03:19 AM. | |
| | #12 |
If you want a solution that doesn't involve a microcontroller, here's a schematic of what Audioguru described. You can tweak pulse widths and LED currents to suit your needs.
| | #13 |
Not that I'm pushing PICs, although I am rapidly becoming attached to them, just compare the attached schematic with that of Little Brave and Nanuk of the North. 1. Fewer components (count 'em) 2. Less construction time (even if you count programming time) 3. Less chance for error 4. Possibly longer battery life 5. Even a dummy like me can do this AllVol
__________________ Creationists have a world of evidence | |
| | #14 | |
Could have fooled me. A 74AC14, A74AC161, 3 resistors, and a capacitor will do it if you do not care about the pause between the color changes and can supply 50mA to the LEDs. D. | ||
| | #15 | |
| circuit, flasher or strobe, led |
| power electronics circuit analysis | ptewright | Electronic Projects Design/Ideas/Reviews | 4 | 23rd August 2009 05:38 AM |
| Circuit functioning very strange. Why? | Cyclone | Electronic Projects Design/Ideas/Reviews | 13 | 19th February 2009 07:27 AM |
| I need help in designing a circuit | chefach | Electronic Projects Design/Ideas/Reviews | 13 | 27th September 2007 12:15 PM |
| Circuit auto OFF feature after no events design | Uman | Electronic Projects Design/Ideas/Reviews | 2 | 3rd May 2004 06:34 AM |
| HELP! a digital signal to close a circuit | fireismyflag | Electronic Projects Design/Ideas/Reviews | 2 | 22nd March 2004 11:46 PM |
