Old 30th January 2007, 08:19 PM   (permalink)
Default Water deicer
How can I build a water deicer to keep water from freezing in a 20oz bottle? I have birds and trying to keep water from freezing.
bdstech2 is offline
Old 30th January 2007, 08:24 PM   (permalink)
Years ago I worked in a biochem lab and they had a cool gizmo that was basically a plastic coated magent and a unit which produced a rotating magnetic field. You put the magnet into a solution in a flask or beaker then put it on top of the unit. Hit the switch and the little magnet starts to rotate at a variable speed. If the water is moving it can't freeze. Maybe not elegant but it beats poisoning the birds with ethylene glycol(antifreeze).
Papabravo is offline
Old 30th January 2007, 08:55 PM   (permalink)
I'm betting moving water will freeze. If you remove energy from the water faster than you are putting it in, it will eventually freeze.
Ron
Roff is offline
Old 30th January 2007, 09:39 PM   (permalink)
how about a small aquarium heater?
EEgeek.net
evandude is offline
Old 30th January 2007, 09:52 PM   (permalink)
He didn't state any requirements. If by removing energy you mean lowering the temperature then yes moving water will freeze but at a lower temperature then water which is standing still.
Water can also be supercooled in the absence of nucleation sites to temperatures lower than 0 degrees C (32 degrees F). Toss in a miniscule amount of impurity and it's like Ice-9
Old 30th January 2007, 10:11 PM   (permalink)
Toss in a minicule amount of impurity and it's like Ice-9
like a bird?
EEgeek.net
evandude is offline
Old 30th January 2007, 10:17 PM   (permalink)
one way to keep the water warm without using a resistance heater is to circulate it through the ground at a depth where the ground is not frozen. Kind of a mini-geothermal system. Of course, this means running a bit of tubing to and from the container and having a tiny electric pump circulate it, so its a bit complicated. But just pushing the water through a buried tube will warm it up enough. It works for my swimming pool just fine.
RadioRon
RadioRon is offline
Old 30th January 2007, 10:18 PM   (permalink)
Water can also be supercooled in the absence of nucleation sites to temperatures lower than 0 degrees C (32 degrees F). Toss in a minicule amount of impurity and it's like Ice-9
That happened to me once. I got in my car one winter morning and touched a bottle of water. It froze INSTANTLY!
Ron
Roff is offline
Old 31st January 2007, 12:00 AM   (permalink)
How about using a peliter module.
mattadler is offline
Old 31st January 2007, 01:20 AM   (permalink)
Peltier heater/coolers are expensive, nichrome wire isn't. A simple piece of nichrome say ripped from a toaster, and a thermistor as biased for a transistor will easily keep the water from freezing. Cheaper easier and just about idiot proof. You just have to water proof the electronics with a potting compound.
straight answer, har har."
Sceadwian is offline
Old 31st January 2007, 01:25 AM   (permalink)
Oh yeah that's a good idea. The bird drinks and it turns to ice in its throat!
Probably freezes him to it too.
Watch it happen:
http://www.youtube.com/watch?v=V3R4VAdCbTg
Oznog is offline
Old 31st January 2007, 01:39 AM   (permalink)
It would require distilled water. That's not likley to form in the dish =) Any agitation in the dish would only help for temperatures relativly close to freezing, they wouldn't work on days when the temperature drops more than a degree or two bellow, unless you really agitated it a lot. Which is more likley to turn the bird bath into a bird blender. A simple resistive heater and a properly located thermistor is easy enough to implement anything else is really too complicated.
Old 1st February 2007, 11:49 AM   (permalink)
how about a small PTC thermistor? As the temperature goes down it will draw more current and heat the bottle. If it's a glass bottle, just attach it to the outside and insulate the bottle. For a plastic bottle you would be best attaching it to a small metal plate bent to fit the curve of the bottle.
By correct choice of thermistor and supply voltage you can adjust the temperature. Electrically you just connect it to a supply, AC or DC, a small mains transformer would be ideal.
G8RPI.
G8RPI is offline
Old 1st February 2007, 01:16 PM   (permalink)
Peltiers are cheap (60mm x 60mm for 12$US), the PSU required to get them to function is the expensive bit! I have an Alinco 32amp variable switch mode PSU that gets my peltier to -38 celcius on the cold side but it draws about 14 amps at 12v.
Why not use a 22R 25w metalclad resistor? Hook it up to a 12v 1amp wall wart and dunk it in epoxy to insulate the ends. That could be submerged in the water to keep it liquid.. Viola, hot tub for birdies!
Shax.
A bus station is where a bus stops...
A train station is where a train stops...
On my desk I have a work station...
Nuff Sed!!!
Shax is offline
Old 1st February 2007, 02:54 PM   (permalink)
Keep in mind that stirring the water by any means adds some heat. Whether or not it's enough must be determined.
stevez
stevez is offline
Need Low Volume Water Pump Noggin General Electronics Chat 27 26th June 2007 05:33 AM
submerging a pressure sensor under water? AndyWatson Electronic Projects Design/Ideas/Reviews 14 26th October 2006 10:38 AM
measuring the resistance of water kleen Electronic Projects Design/Ideas/Reviews 20 6th August 2004 04:50 PM
water spray cool-agent Electronic Projects Design/Ideas/Reviews 4 13th April 2004 06:08 PM
water level controlled motor on/off switch Lalit Electronic Projects Design/Ideas/Reviews 12 30th August 2003 02:33 PM
