Old 28th January 2007, 05:37 PM   (permalink)
Default solar powered battery
dear members,
i was interested in charging a 6v, 4Ah battery using a 3Watt(6V, 0.5mAh) solar power panel... What would be the best way to do this.... Pls help me out with the circuits involved.
Regards,
akshayd
akshayd is offline
Old 28th January 2007, 05:43 PM   (permalink)
If it's got a diode built in, then just connect it directly across the battery, if it's not got a diode, then connect it through a diode.
I presume you mean 0.5A solar cell?, it won't have enough power to overcharge the battery!.
Old 28th January 2007, 05:57 PM   (permalink)
Default yes you are right
It is a 0.5A solar panel.... But, still do i not have to include a charging circuit that would prevent unnecessary discharging or maybe overcharging?
akshayd is offline
Old 28th January 2007, 06:32 PM   (permalink)
A simple diode prevents discharging (as I mentioned above), and (as I also mentioned above) your panel isn't big enough to over charge it!. You will probably be very disappointed with how much power your panel will provide to the battery - most people are!.
Old 28th January 2007, 09:20 PM   (permalink)
You need more than 6V to charge the battery; you cell needs to be at least 7.6V to fully charge it, assuiming it's a lead acid battery that is.
Screen name: Aloone_Jonez
Hero999 is offline
Old 29th January 2007, 01:18 AM   (permalink)
the solar panel will produce 6V at 0.5A only at noon on the equator on a bright sunny day. Any other time or behind clouds or behind a window's glass will reduce its output a lot.
Your battery will never be fully charged and will charge a little for only about 1 hour each bright sunny day.
audioguru is offline
Old 29th January 2007, 05:23 PM   (permalink)
though it is specified as a 3W module.... when i observed the output voltage across it terminals.... it was around 9 V at noon.... but the current output was only around 400mA. I also wanted to know, if i reduced the battery capacity, what kind of charging circuit i might have to employ?
akshayd is offline
Old 30th January 2007, 04:11 AM   (permalink)
It depends on the chemistry of the battery... LeadAcid, NICAD, NIMH, LithiumIon, etc
kchriste is offline
Old 30th January 2007, 08:23 AM   (permalink)
You first need to accurately record what the panel will actually provide over a number of days - it's probably too small to overcharge anything much!.
There are plenty of controller designs about if you google - but not for anything as small as you've got, because there's no need.
Solar battery charger with moving panel Hanford Electronic Projects Design/Ideas/Reviews 6 8th October 2006 01:38 PM
Charging a 12v battery with Solar panel.. barrymons Electronic Projects Design/Ideas/Reviews 11 21st April 2006 12:44 AM
Battery powered circuit Scarr General Electronics Chat 1 12th October 2005 04:05 PM
Solar Powered Toy Car Spectacular Butter Electronic Projects Design/Ideas/Reviews 11 19th October 2004 02:10 PM
converting some solar powered garden lights cool-agent Electronic Projects Design/Ideas/Reviews 1 2nd April 2004 04:39 PM
