Notices
Old 24th January 2007, 02:11 PM   (permalink (permalink))
Smile Squared wave converter to Triangle wave
I built a 74HC14 squared wave oscillator that I controlled using a capacitor and 12 pots (variable resistors) in series. By ear I tuned each one to a note in the scale. Now I want to change the squared wave to a triangle wave. How do I do this? Can you proposed a circuit?
prprog is offline
Old 24th January 2007, 03:48 PM   (permalink (permalink))
Not so easy. The usual way of getting a triangle (sawtooth) wave is to charge a capacitor with a constant current and then discharge it quickly.
However, the charge rate is constant and therefore the amplitude reached will depend on for how long the charge is going on.
Since the period of your square wave depends on which note (frequency) you select, the amplitude of the triangle will get less as the frequency rises.
There will be ways around this, but it gets complicated.
Why do you want a triangle wave? It won't sound much different to a square wave.
dch222 is offline
Old 24th January 2007, 04:30 PM   (permalink (permalink))
i suggest you use an integrator built from op amps.. just use the frequency to compute for the capacitors and resistors..
wishbhonez is offline
Old 26th January 2007, 04:09 PM   (permalink (permalink))
dch222
Can you post a circuit ?
This is for Wind Synthesizer. So far I manage to generate 3 octave by using a 4040 IC to divide the original square wave. It will be nice to have different type of wave , to get other sounds.
thanks,
PRPROG
prprog is offline
Old 26th January 2007, 06:09 PM   (permalink (permalink))
Can't remember where I found it but it should be just the job
Angry!? I'm absolutely electrolytic!
Will have to make do with myspace now I guess...
Dr.EM is offline
Old 26th January 2007, 08:28 PM   (permalink (permalink))
I made a circuit similar to that many years ago. It's a feedback loop that maintains constant triangle amplitude as the frequency varies. The only problem I had was, as anticipated, there was a finite response time. When the input frequency changes abruptly, the triangle amplitude takes some time to settle.
Ron
Roff is online now
Old 27th January 2007, 02:15 PM   (permalink (permalink))
Wow! Can the same technique be used to produce sinewaves?
Screen name: Aloone_Jonez
Hero999 is offline
Old 27th January 2007, 02:43 PM   (permalink (permalink))
Once you have generated the triangular wave, you can buffer and shape it.
I want to study this circuit
eng1 is offline
Square wave to sine wave converter ghauri Electronic Projects Design/Ideas/Reviews 18 20th May 2008 07:15 PM
USB - TTL Converter samltd Electronic Projects Design/Ideas/Reviews 5 7th July 2006 09:46 PM
Triangle wave generator 4electros General Electronics Chat 6 14th January 2006 03:40 AM
circuit help: square and sin wave input = square wave output spyghost Electronic Projects Design/Ideas/Reviews 2 28th April 2004 01:08 AM
