Old 20th January 2007, 10:29 PM   #1
Default Potentiometer link to linear actuator
Hello All
My project is a trailer braking system for a car towed trailer. I want to control the trailer brakes from the brake pedal of the towing vehicle i.e. car or jeep). To do this i was thinking of using a linear potentiometer connected to the brake pedal, this would then send a signal to a linear actuator to control the master cylinder (piston that forces hydraulic fluid to wheel brakes). The further the piston moves the more pressure in the system thus a greater braking force.
The movement of the piston is controlled by the movement of the brake pedal
What i need to know if is, if it is possible to link a linear ( or rotary) potentiometer to a linear actuator ( servo or stepper)
(the position of the actuator is controlled by the position of the potentiometer)
Are the other methods to achieve this?
Looking forward to you thoughts,
Regards
Caff
dermotcaf is offline
Old 21st January 2007, 12:39 AM   #2
It is unusual for a trailer to have hydraulic brakes. The only time I saw one, the hitch on the trailer was mounted so it could slide and was connected to the master cylinder. When the car slows, the trailer surges ahead, applying the brakes. A shock absorber/damper is needed in parallel with the master cylinder. This system is simple and works well.
Russlk is offline
Old 21st January 2007, 10:28 AM   #3
Electric brakes ... not a good idea what if the fuses pops?
Surge brakes are real simple with cable or hydraulics and they work.
based on the force against the car not the position
of the brake pedal
HYDRAULIC SURGE BRAKE COUPLERS
For $99US
http://www.championtrailers.com/Brake_Couplers.html
Good luck think failsafe safety
Aeroplane is offline
Old 22nd January 2007, 07:21 AM   #4
read atashed document... in this are some usefull links (is in roumanian language, but.. are schematics)
niq_ro is offline
Old 22nd January 2007, 07:46 AM   #5
Also, a potentiometer would wear out quickly.
Remember that it is a contact sliding on a carbonised track.
Len
ljcox is offline
Old 22nd January 2007, 12:11 PM   #6
Thanks niq ro, really helpful attachment,
Caff
actuator, linear, link, potentiometer
Need a quick circuit for a reversing linear actuator switch... um.. QUICK iso9001 General Electronics Chat 5 28th October 2006 06:38 AM
Need some other idea on miniature linear actuator mister_e Datasheet/Parts Requests 4 28th July 2006 07:57 PM
Ti-83 plus wireless link circuit help Halogrunt1234 Electronic Projects Design/Ideas/Reviews 41 13th April 2006 02:28 AM
Mini-Space Telescopic Cylinders, Linear Actuator, SMAs sprin odense Robotics Chat 0 10th August 2005 12:36 AM
pins explain? motorized potentiometer..? Ctrl_Alt_Del General Electronics Chat 1 6th July 2005 12:05 PM
