Old 20th January 2007, 09:18 PM   (permalink)
Default How to generate Negative powser supply from +5V ?
I would like to use a controller-less LCD. I have to supply (-19V) (negative power) to LCD controller. How can I generate it ? my circuits is powered by +5V regulated supply (I'm using a PIC microcontroller).
Best regards
http://www.pocketmt.com the GLCD Font Creator home page
octal is offline
Old 20th January 2007, 09:22 PM   (permalink)
Easy answer! - DON'T use a controllerless LCD, it's far too much work for too little gain.
But to get -19V it would be easiest to get it from the transformer if it's a mains project, for a battery project either an inverter and transformer, or inverter and voltage multiplier (assuming current requirements are low).
Depending on the PIC, you may even be able to use it's PWM module to generate a suitable voltage, check how the PICKit1 generates Vpp.
Old 20th January 2007, 09:27 PM   (permalink)
Thank you Nigel ... but my project is TO create a cheap intelligent controller to this kind of LCD. I have found a set of about 250 LCD at a very very low price (about 3 euro each) and they are 240 x 220 Pixels ... Actually I'm using an external negative power source, and my controller is almost working now. I just need to generate a negative power supply from 5 volt ...
Best regards
octal is offline
Old 20th January 2007, 10:00 PM   (permalink)
It's called a buck-boost converter.
http://www.google.com/search?q=Buck-...UTF-8&oe=UTF-8
Screen name: Aloone_Jonez
Hero999 is offline
Old 21st January 2007, 04:39 AM   (permalink)
if the -19v is just a micro-current bias voltage, a capacitor charge pump inverter might work too, eliminating the need to rely on magnetics
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline
Generate Negative Voltage Dc5e Electronic Projects Design/Ideas/Reviews 15 10th September 2008 06:44 PM
create component multisim8 max1000000 General Electronics Chat 1 4th December 2006 04:02 AM
Power Supply Experts!! Need help with KEPCO Labs Power Supply headbuttking2 General Electronics Chat 1 24th October 2006 02:05 AM
how can i produce a negative supply voltage from +12V? spyghost Electronic Projects Design/Ideas/Reviews 15 3rd June 2004 07:05 AM
Power supply/ current supply design inkedallusion Electronic Projects Design/Ideas/Reviews 1 17th December 2002 02:10 AM
