Old 19th January 2007, 04:40 PM   #1
Default Lead Acid battery charger
Hello everyone,
I am building a Lead acid battery charger for my project. I have a power converter that converts 110V to 12V, 5V and 3V. I am using 12V to run my project and i want to build a back-up power so I bought a Lead acid battery and now i m trying to build a charger. MY Idea is to run 12v from the power inverter and if that fails using diodes Lead acid battery will take over.
NOw i know that my Lead acid battery will produce about 12.4V so i had to bring my 12V from power converter to 13.8v so my project keeps running on that and not on battery.
so need help building charger from using 13.8V from power converter to charge a 12V battery with 7A. my input is 13.8V and i need to charger 12V lead acid battery with 7A.
Please HELP.
Thank You All
manojp01 is offline
Old 19th January 2007, 06:17 PM   #2
hi manojp.
there are some very recent postings regarding sealed lead acid, 'floating'
chargers. Do a forum search.
If you cannot find the postings, let us know, someone will guide you.
Regards
Ericg
ericgibbs is offline
Old 20th January 2007, 07:26 PM   #3
Why are you converting 13.8V (which would be perfect for float charging a lead acid battery) to 12V (which won't be enough to charge a lead acid battery)?
if I know the answer.
Hero999 is offline
Old 21st January 2007, 12:48 AM   #4
You don't need 7 amps to charge the battery, it will be floating most of the time. I looks to me that you can just connect the 13.8 volt source to the battery. I assume that is why you chose that voltage.
Russlk is offline
Old 29th January 2008, 05:57 PM   #5
Hiya, try my circuit out. Despite the fact I am having problems with it at the moment, it has been operating for 8 years or so.
http://www.electro-tech-online.com/e...-new-post.html
Cloud9 is offline
Old 29th January 2008, 06:17 PM   #6
Default Lead Acid Charger.
I,think the charger at this link is a good charger http://www.talkingelectronics.com/pr...er-12vSLA.html
OY2L is offline
acid, battery, charger, lead
constant voltage, constant current Lead Acid Battery Charger Erwin_Macaraig Micro Controllers 1 4th October 2008 01:26 AM
Lead Acid Battery Charger Help Request jagzviruz Electronic Projects Design/Ideas/Reviews 17 16th January 2007 11:46 AM
DS2438 with 12V lead acid battery monkeytennis General Electronics Chat 2 29th August 2006 01:45 PM
Lead acid battery efficiency Oznog General Electronics Chat 2 22nd September 2004 07:08 PM
12v Sealed lead acid battery charger andi_n2004 Electronic Projects Design/Ideas/Reviews 1 27th April 2004 01:52 PM
