+ Reply to Thread
Page 3 of 3
First 1 2 3
Results 31 to 35 of 35
Thread: Ac step down
  1. #31
    Fahime Newbie
    Join Date
    Oct 2006
    Posts
    136
    Quote Originally Posted by audioguru
    The LM317 needs a minimum of a 10mA load or a 120 ohm resistor between ADJ and output or its output voltage will rise on some of them. Then the resistor from ADJ to ground will need re-calculation.
    Thanks, The problem was that.
  2. #32
    Fahime Newbie
    Join Date
    Oct 2006
    Posts
    136
    Dear Audioguru,
    I read the datasheet of LM317. But I can't figure out how you undrestood the resistor between Adj and output should be 120ohm. Could you please explain it for me? It would be a good experience for me.
  3. #33
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,761
    Quote Originally Posted by Fahime
    Dear Audioguru,
    The datasheet specifies "a minimum load current". Without a load then the current in R1 and R2 sets the minimum load current.
    Many people see the schematic on the first page of the datasheet with the 240 ohm resistor for R1 but don't notice that the IC is the more expensive LM117 with half the minimum load current of the less expensive LM317.
    The minimum load current is spec'd with a Vin - Vout voltage of 40V and is less with less voltage but it doesn't cost any more to make R1 always 120 ohms with an LM317.
  4. #34
    Fahime Newbie
    Join Date
    Oct 2006
    Posts
    136
    Thanks alot. It was really helpful.
  5. #35
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    12,945
    Which really annoys me, they shoud change the datasheet to show a 120hm: resistor!
    if I know the answer.
+ Reply to Thread
Page 3 of 3
First 1 2 3
  1. step motors?
    By mr.engineering in forum Robotics Chat
    Latest: 27th December 2006, 02:59 AM
  2. DC-DC Step up voltage converter
    By miaomiaooh in forum Electronic Projects Design/Ideas/Reviews
    Latest: 30th September 2006, 06:10 PM
  3. Need a little help with my project (Step motor driver).
    By Ckramer in forum Electronic Projects Design/Ideas/Reviews
    Latest: 26th April 2006, 10:59 PM
  4. Step motor wiring diagram?? need help 5V - --- > 12V
    By linuxglobal in forum General Electronics Chat
    Latest: 22nd February 2006, 02:19 PM
  5. step motor test
    By xjackal in forum General Electronics Chat
    Latest: 2nd September 2003, 04:22 AM
Tags for this Thread
