Old 17th January 2007, 05:09 AM   #1
Default First scratch built bench power supply
I suppose sooner or later a beginning electronics hobbyist builds his own bench power supply. Probably like a rite of passage. So I’ve finished mine, and my first project completely designed and built from scratch instead of kits.
I got some help on these forums, which helped me learn how to handle thermal resistance calculations and how to connect a shunt for an ammeter with a common ground.
So here are some photos and specs:
Input: 120VAC 60 Hz
Outputs:
Fixed voltages: 24, 18, 12, 9 and 5, at up to 700mA
Variable voltage 1.3 to 30 Volts up to 2 Amps
Features:
LED meters for variable voltage output, and for current drawn from any voltage supply
Coarse and Fine voltage adjust
Microprocessor controlled fan speed with over-temp warning, temp sensor failure warning, and POST.
I had originally planned to control the fan with a simple Schmitt trigger using a 555 timer. But in the mean time I learned to program microprocessors, so this is also my first operational project using a PIC.
It’s all stuffed in a Serpac project box that is entirely too small. The three circuit boards are 1) linear regulators & heat sinks, 2) rectifier, filter cap and bleeder, and 3) PWM Fan control and adjustable shunt on the return.
Cheers,
-- Dan
First scratch built bench power supply-p1160006f700.jpg   First scratch built bench power supply-p1160008f700.jpg   First scratch built bench power supply-p1160014f700.jpg
Revolvr is offline
Old 17th January 2007, 05:48 AM   #2
Hi Dan,
Its outside looks very nice. Its inside is too crowded (as you know)
If it is set for 3.3V at 2A then the poor variable regulator must dissipate about 70W and it will cook itself and everything inside. The tiny fan will spin like crazy.
But if the variable regulator is an LM350K then it will reduce its output current to as low as only 250mA to protect itself.
audioguru is online now
Old 21st January 2007, 11:25 PM   #3
Did you use a separate regulator for each of the fixed voltages?
RDL2004 is offline
Old 22nd January 2007, 12:38 AM   #4
Yea it's just a chain of 5 linear regulators. The 12V also feeds the fan, the 5V also feeds the meters and microprocessor. The LM350 is in the TO-3 package.
-- Dan
Revolvr is offline
bench, built, power, scratch, supply
Got a new EVBoard How do i supply power to it? cubdh23 Micro Controllers 2 3rd August 2007 10:39 AM
Bench Power Supply Ayne Electronic Projects Design/Ideas/Reviews 12 1st November 2006 03:12 PM
need help with power supply parts very info... rodniepr General Electronics Chat 0 6th April 2005 04:33 AM
PC Power Supply Problems brentonw2004 Electronic Projects Design/Ideas/Reviews 3 29th March 2005 12:01 PM
Power supply/ current supply design inkedallusion Electronic Projects Design/Ideas/Reviews 1 17th December 2002 02:10 AM
