Old 14th January 2007, 10:43 AM   (permalink)
Originally Posted by dknguyen
Oh, here is the datasheet for the camera-colour sensor I was talking about...
http://www.rev-ed.co.uk/docs/axe045.pdf
Here is the manufacturer:
http://www.taosinc.com/category.asp?cateid=11
No, I do not understand because you need ambient light to be the source for the reflected light off of the object in order to detect colour. Do you know the process by how you see light? Ambient light hits an object. The object will absorb some of the frequencies of light that reach it, but it will reflect certain frequencies. These specific reflected frequencies that hit your eye determine the colour you see. Therefore you need ambient light. If the ambient light is missing certain frequencies of light that the object would normally reflect, the object's colour will be distorted because it is not able to reflect these frequencies since they are not there. BUt then all you need to do is have a bright white light nearby to produce these missing frequencies.
In actuality, all the ambient light is absorbed by an object (rather than some of them) and certain frequencies are re-emitted (rather than reflected).
I think you missed what he posted earlier.
Originally Posted by ikalogic
Well, the idea i had (which needed to ignore ambiant light) was to use 3 LEDs (one of each cooulor, and 1 LDR in the midle. this idea was proposed in one of my electronics magazines, but they said that the sensor had to be totally protected from ambiant light.
The idea is to send Only red light, and record the LDR reading
Send Green only, then record the LDR reading,
Blues Only, the record again the LDR reading,
you get the RGB values of the Object's surface. (sure after some calibration) but the problem with this idea is -as you sure realized- is very sensitive to ambiant light.....
He wants to take the RGB readings seperately, which is why he does not want the "white" (ambient) light.
Sig239 is offline
Old 14th January 2007, 10:45 AM   (permalink)
that's was at first, we then found agreement dknguyen and me!
we concluded that i would apply filters on 3 different LDR...
Ibrahim Kamal
check my electronics and robotics page: http://www.ikalogic.com/
ikalogic is offline
Old 14th January 2007, 11:07 AM   (permalink)
hi ikalogic,
Just a thought will reading the latest posts, jogged my memory cell.
Used to work on a polychromater system.
It used a prism to diffract the 'white' light source into the spectrum, photo
detectors placed along the spectrum to detect the intensity of the light
at that point of interest in the spectrum.
I still think the optical filters will be best for you experiments.
As suggested by our co-poster, bog standard red,green, blue plastic filters
using a 'white' light illumination source. Check the light/resistance curve
for your LDR, see if it covers the light range of your filters.
Regards
EricG
ericgibbs is offline
Old 14th January 2007, 11:29 AM   (permalink)
Yes, but now the accuracy of your results will depend on the "purity" of the white light. I suppose you could compensate for it, but that would add useless complexity right? Since you would have to compensate differently with each light source. The advantage of using the RGB light sources is that you only calibrate once. You will know the purity specs of your filters when you buy them, then it is just a matter of making sure the amount of light emerging from the other side of the filters are the same (dimmers? to adjust). I believe measuring brightness is easier than measuring purity, and you always use the same light sources. I assume these are some of the reasons the folks who wrote the magazine article had in mind. Clearly both methods have compromises, I guess it just depends how you will be using it. I agree with everything dknguyen posted earlier, I just wasn't sure if he was clear on what your original intentions were. Good luck and keep us posted!
EDIT: I couldn't see erics post until I hit the submit button on my post! I like the prizm idea.
Sig239 is offline
Old 14th January 2007, 12:20 PM   (permalink)
hi sig,
In some of the 'light' measurements systems I have used, I found that a
lookup table in the MCU, [ created in a calibrated set up] worked well.
By using the 'address' calculated from the apparent light intensity as a pointer
to the table, it was possible to give fair measurement repeatabilty.
Nice chatting, looking fwd to your post guys.
EricG
Old 14th January 2007, 02:59 PM   (permalink)
I haven't built any of these projects, but a couple at the bottom of the page might help you...
http://www.ullasmann.eu/Tiny13.htm
Seem to be complete and well documented.
HarveyH42 is offline
Old 14th January 2007, 03:10 PM   (permalink)
I should have said a red band-pass filter, although filters do exist that just block red (these are actually yellow filters! since they pass green and blue. green + blue = yellow).
I think you're confusing things, a red band stop filter will appear cyan, green + blue = cyan, red + green = yellow.
Screen name: Aloone_Jonez
Hero999 is offline
Old 14th January 2007, 04:37 PM   (permalink)
Ok Now i AM seriously lost!
If i take a piece of transparent film, put some blue marker on it, so that it is still transparent but everything looks blue when looking through it, Is this a filter that is passing blue light only? (sorry i just got a litle confused, too much of blue+green+yellow+red = ? ....) !
Ibrahim Kamal
ikalogic is offline
Old 14th January 2007, 05:39 PM   (permalink)
There are three different coloured cone cells on the human retina, red, green and blue.
When red and green are equally stimulated we see yellow.
When green and blue are equally stimulated we see cyan.
When red and blue are equally stimulated we see magenta.
When they're all equally stimulated equally we see white.
A blue filter blocks all other colours except blue.
A red filter blocks all other colours except red.
A green filter blocks all colours extepr green.
The above filters are addivite primary colours, they are used for mixing light, if you look at a TV screen closely then you'll see rows of red, green and blue dots.
A yellow filter blocks blue and passes only red and green.
A magenta filter blocks green and passes only red and blue.
A cyan filter blocks red and passes only green and blue.
The above filters are subtractive primary colours, they are used for mixing pigments, you'll often see them printed on the corners of magazines or packaging and if you looked at the pages through a microscope you'll see that all the images are made of these three colours.
Putting a magenta filter on top of a yellow filter gives red, because the magenta filter blocks green and the yellow fliter block blue leaving only red because the only colour that they both pass is red.
Putting a cyan filter on top of a yellow filter gives green because the yellow filter blocks blue and the cyan filter blocks red, leaving only green because the only colour the both pass is green.
Putting a magenta filter on top of a cyan filter gives blue because the magenta filter blocks green and the cyan filter blocks red leaving only blue because the only colour they both pass is blue.
http://en.wikipedia.org/wiki/Color_theory
Hero999 is offline
Old 14th January 2007, 08:08 PM   (permalink)
Ah, yeah. I was sitting here trying to figure out what blue + green makes and the closeset thing I could come up with was yellow. Even though I'm aware of CYM and RGB, my preschool knowledge of colours always seems to take control so I keep on thinking of just RGBY since I've never had anything to use it for anything and solidify it in my head. I then end up thinking RGB is additive and RBY is subtractive. As a result, I end up mistaking cyan for green and forgetting that red and green can mix! I always forget about CYM until someone points it out. Colour mixing seems to come up so rarely in control and power systems.
I also forgot about light being additive but filters being subtractive.
dknguyen is offline
Old 14th January 2007, 08:28 PM   (permalink)
Yes but once you know the science it all becomes logical, especially when you consider that mixing red and green paint makes brown which is a dim shade of yellow; this is due to the small amount of red and green light reflected. I also remember mixing blue and yellow in equal quantities which resulted in a very dissapointing grey-green.
Some colours are very hard if not even damn near impossible to mix using the preschool RYB system which I suspect exists from before they developed proper pigments. Some would also say that printing cyan is a shade of blue and printing magenta is a shade of red.
I think, I've stumbled on the fact that you can make red from magenta when I was playing around with paints in art class at school.
Hero999 is offline
Old 14th January 2007, 08:40 PM   (permalink)
Isn't brown actually a dark shade of red? Where does brown go on the colour spectrum anyways? It doesn't make sense if it's a yellow since it's smackdab inthe middle of the transition between yellow-> red or yellow->green
dknguyen is offline
Old 14th January 2007, 10:37 PM   (permalink)
Well, back when I use to paint... Red+green = Brown
Blue+Orange = Brown
Yellow + Violet = Brown
Old 16th January 2007, 10:50 PM   (permalink)
Brown is more a dark shade of orange, but some might say yellow.
Anyway aren't you colourblind or am I confusing you with someone else?
I am slightly red-green colourblind, so I might get subtle shades of brown, orange, yellow, red and green confused but I never get distinct colours confused, i.e. I can tell the difference between red, orange, yellow, green and brown bands on resistors.
Hero999 is offline
Old 17th January 2007, 12:16 AM   (permalink)
I am, that's why I'm not sure if brown is a dark shade of red or not. Because under some conditions I see it as a really dark red...then again, I can also imagine why green looks like red sometimes.
dknguyen is offline
RS232 TX, RX & GND wire colors? William At MyBlueRoom Electronic Projects Design/Ideas/Reviews 2 24th August 2008 04:10 PM
RGB LED Fader - Purely random colors? indecided Electronic Projects Design/Ideas/Reviews 5 28th November 2005 12:36 PM
how does scanner identifies the colors on paper Mahdik General Electronics Chat 2 11th May 2005 09:30 AM
how can i sense colors with cny 70? kenanizmirli Robotics Chat 6 6th March 2004 12:21 PM
differentiate between monostable, astable and bistable mu... shweeeet General Electronics Chat 1 3rd June 2003 09:47 AM
