Old 9th January 2007, 04:37 AM   (permalink)
Default Got an Idea but I need some thoughts on it
Well I've gotten bck into electronics recently after not really messing with them in about 4 years and I've got a project going but I kinda want someone else to verify that my idea will work before I go hardcore building it. Now onto the project. I'm wanting to make an IR switch for my lights in my room, that being said my plan was I've got this IR Detector Module that I got in a grab bag at radioshack when they were selling off their inventory, its a GP1U52X Infarared Reciever/Demodulator its got 3 pins Vout, Vcc, and GND. would this work the same way as a transistor basically? my plan was to wire that (if it worked like a transistor where when it got ir signal it opened the way up) to a relay where the light switch is. Thebasic idea being the ir reciever completes the circuit when it recieves ir signal then activating the relay and flipping the switch. Can anyone verify that this ir reciever works like I am thinking? IR is confusing me but I'm trying to figure it out. Thanks for any replies and sorry you had to read all that.
psecody is offline   Reply With Quote
Old 9th January 2007, 05:15 AM   (permalink)
The IR receiver's output is the demodulated IR signal with the carrier removed. These modules are really quiet useful, but it does not work like you think. The easiest way to use it as a switch as you're thinking about would be to create a transmitter that sent just a constant carrier signal (usually about 38khz but you'd have to check the specs for your module) then that output line would be high all the time, which you could use to drive a transistor to switch your relay. You could use the module with a PIC or AVR to add significantly more functionality past an on/off switch.
straight answer, har har."
Old 9th January 2007, 05:36 AM   (permalink)
ok but minus the transmitter what would I need to add onto the recievers circuit to make this work? I don't quite get how the reciever module works with three leaad what is actually happening?
Old 9th January 2007, 05:43 AM   (permalink)
They're pretty simple. VCC is obviously power in, GND is obviously ground and "Out" is a logic output The module itself has circuitry which amplifies and demoduletes an IR carrier signal, most IR remotes work around 38khz or so. They have to modulate the light otherwise ambient sunlight or incandescant bulbs could cause your TV to turn on. You'd have to check the modules specs but it's likley just a transistor that connects the out line to VCC when it detects the carrier. It's not going to control a relay but it should be able to source enough current to trigger another transistor to drive your relay. Then when the IR carrier is detected it will turn the relay on and the relay will de-energize when the carrier is removed. This does NOT work like a normal remote control though, you'd have to send the carrier frequency all the time, TV style remotes only send small packets of data. A simple 555 timer could easily generate the carrier required, all you'd need is an IR LED
Old 9th January 2007, 08:04 PM   (permalink)
ok so is there anyway to wire this so that once the relay is activated it will stay in position until the ir reciever recieves another signal? because I don't want to have to keep sending it a constant signal to keep the lights on or off I just want to be able to send it a packet and activate it then another packet to stop it. By the way thanks Sceadwian for all the answers to all my stupid questions, I appreciate it.
Old 9th January 2007, 08:32 PM   (permalink)
You need encoders and decoders - basically you're looking at micro-controllers, either pre-programmed (try Holtek) or program them yourself - you can check my tutorials for doing just what you want!.
Old 9th January 2007, 08:52 PM   (permalink)
For simple on and off control, the IR receiver could trigger a flip-flop IC. Push the transmitter button and the light turns on. Push the button again and the light turns off. The flip-flop drives a transistor that drives the relay.
The IR receiver was made by Sharp and is 40kHz. Even they don't have a detailed datasheet for it anymore.
Old 10th January 2007, 04:15 AM   (permalink)
oh I have the datasheet for it still I jusat found it in my old electronics bin. Could you explain this flip flop IC, I've seen it mentioned but don't know anything about it. Sorry for all the ignorance but I never used IC's when I was into electronics way back when and am just now starting to experiment with them. Thanks for everything guys I really appreciate it.
Old 10th January 2007, 03:13 PM   (permalink)
I don't want to design a circuit for an obsolete IR receiver IC. RadioShack sells old crap. Like Maplin and Dick Smith.
There are some kits on the market and even some IR remote controlled light switch products. Some even dim the light.
Old 10th January 2007, 05:24 PM   (permalink)
yes but see I don't want to buy one pre made and I don't want anyone to design it for me I'm using this as a circuit to learn on. The only problems that I am having is that I'm not sure about IC's because I avoided them like the plague when I was into electronics back in the day because I saw them as hard to get in our little town. could you give me a number for the flip flop IC and I'll take it from there. With that IC I can avoid the microcontroller buying process because I don't feel that I'm ready to use them quite yet. Thanks
Old 10th January 2007, 05:51 PM   (permalink)
A CD4013 is a dual D flip-flop IC. It needs a positive-going clock input for its output to toggle, but your IR receiver's output might be negative-going so a transistor should be used as an inverter in between them.
Lookup how to power and how to connect a CD4013 D flip-flop in Google. You might even find a whole IR remote control circuit.
Old 10th January 2007, 05:56 PM   (permalink)
It depends if you want it useable or not?, with a micro-controller you can turn the light on, you can turn if off - EXACTLY as I presume you want it to work. With the flip flop ANY remote control will turn it ON and OFF, possibly repeatedly? - and even incoming sunlight, or energy efficient lights, may trigger it.
Old 11th January 2007, 02:19 AM   (permalink)
I learned to program a micro controller before I even understood how a flipflop worked. You're never ready for them, you just have to dive in and go through the learning curve like anyone. They can be frustrating, but their main advantage of using them is the 'what else' factor. Once you're using a micro controller 'what else can I add' starts popping up everywhere and you'll never know why you tried to do it all with discrete logic before. You're liable to burn out your first few chips weather they're simple logic IC's or micro controllers, so just pic a nice cheap MCU and buy a half dozen of them.
Old 11th January 2007, 02:57 AM   (permalink)
Like Nigel mentioned, I would advise against the flip-flop because everytime you change channels on your TV, the lights would turn on/off.
A microcontroller is the best choice for this project, with a PLL/tone detector a distant second.
kchriste is offline   Reply With Quote
Old 11th January 2007, 03:11 AM   (permalink)
A PIC or AVR will cost you less than 5 dollars, even for the high end ones. The cheapest AVR's and PIC's are under 50 cents per chip. Programmers are as simple as a few resistors/transistors hooked up to a parallel printer port home built. Or 20-50 dollars for an inexpensive development board.
An old idea (for the Atari 8 bit computer) David Brown Electronic Projects Design/Ideas/Reviews 3 27th May 2005 08:17 PM
Any idea to count 15minutes using simple electrical circuit violet General Electronics Chat 4 7th March 2004 01:54 AM
Either a good idea, or I don't know what I'm talking about. Electric Rain General Electronics Chat 21 28th January 2004 03:40 AM
need idea for 'water quality measurement in aquarium' kumar_3k Electronic Projects Design/Ideas/Reviews 2 5th November 2003 04:40 PM
>>>A Circuit modificaton idea... Someone Electro Electronic Projects Design/Ideas/Reviews 2 2nd November 2003 04:50 AM
