I have a 5.1 ch av amp rated 100wrms total ,5 channels. This leads me to believe it is about 20wrms per channel with ALL channels operating at max. My question is: if I use the line outs of this amp to feed a separate power amp for three channels, and use the speaker outs for only two channels on the av amp, will the av amp supply 50wrms to each channel or will it still be about 20wrms? Thanks in advance.
This may be the case; however, typically the manufacturers of consumer audio equipment rarely desine their products exactly the same way. It's all going to depend on the specific amplifier, however, I would be surprised if you get the two channels of 50W's unless the amplifier is extremely high end. Do you have a manual? It's probably written in the spec. section of the manual. If not, try to do a web search.
__________________ "If it sounds good, it IS good" - Duke Ellington "You see, wire telegraph is a kind of a very, very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? And radio operates exactly the same way: you send signals here, they receive them there. The only difference is that there is no cat." - Dr. Einstein | |
| | #3 | |
| avamp, power, questions |
| PIC power on problems.... | SnM | Micro Controllers | 5 | 17th November 2007 11:40 PM |
| 24v DC Power Supply (Help & Information Wanted Urgently) | ampthetex | Electronic Projects Design/Ideas/Reviews | 5 | 17th November 2006 01:45 PM |
| [help] Power consumption issue on bullet counter project * | Lanzer | Electronic Projects Design/Ideas/Reviews | 13 | 26th August 2005 07:06 AM |
| PIC power supply problems | evandude | General Electronics Chat | 5 | 2nd March 2004 08:39 PM |
| Electronics Pre-Test questions | Mike_07 | General Electronics Chat | 0 | 13th November 2003 03:22 AM |
