Hi all, new here so hopefully you can help. I'm looking for a simple circuit to allow me to test the level of a rechargeable NIMh 1.5v AA battery. Preferably using an LED Bar Graph display. Any help would be appreciated, Cheers Rob | |
There really isn't one - you can measure the voltage across it, but it's a VERY poor indication of the state of charge.
How can there not be one, there must be some way of doing it??
| | #4 | |
| | #5 | |
If you want get a better indication of the charge in the battery you will have to integrate the charge/discharge current with respect to time. This is getting away from the idea of "simple". There are integrated circuits which implement a "gas gauge" function for use in laptop batteries etc, try searching the Maxim website, I think they do one or two of these things. JimB
__________________ Experience is directly proportional to the value of the equipment ruined. | ||
| | #6 | |
| | #7 |
Testing a batteries state of charge is not that complicated. Open circuit voltage is as Nigel said relativly useless by itself. But you can get a very good idea of the state of charge of a battery by comparing a no load voltage with a loaded voltage. A good 'load' current to put a cell under is 1/10th of it's rated capacity. So for a 2000ma NiMh, put it under a 200ma load and compare the voltages. You'll get a pretty decent representation of the battery charge. If you say compared 10ma 100ma and 500ma load voltages with the no load voltage I'm sure you could calibrate a 'gas gauge' style meter within 5% accuracy. If you've ever seen those built in battery gauges on AA's (I think Energizer and Duracell both did this for a time) when you press the side of the battery it shorts the battery across a thermal strip and the relative current through it causes it to heat up and show a charge state, same general concept.
__________________ "Because I be what I be. I would tell you what you want to know if I could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." Last edited by Sceadwian; 7th January 2007 at 05:25 PM. | |
| | #8 | |
| | #9 |
Yes, but a solid state digital circuit such as perhaps a PIC or other compareable micro controller with an ADC can read the loaded voltage (switched easily via a transistor) in less than a milisecond. At 1 reading a second that's 1ma average draw for a 1 second update on battery capacity with a 100ma draw... Check it once a minute and the wasted current is almost less than self discharge. I wouldn't recommend anything less than a 1ms 'short' to the load before sampling simply because internal surface charge of the batteries chemistry can artificially 'liven' the loaded voltage for a brief period of time.
__________________ "Because I be what I be. I would tell you what you want to know if I could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." Last edited by Sceadwian; 7th January 2007 at 05:43 PM. | |
| | #10 | ||
__________________ Experience is directly proportional to the value of the equipment ruined. | |||
| battery, circuit, monitor |
| primitive early design for battery charging | faomari | General Electronics Chat | 40 | 13th September 2009 01:46 AM |
| constant voltage, constant current Lead Acid Battery Charger | Erwin_Macaraig | Micro Controllers | 1 | 4th October 2008 01:26 AM |
| Replacing a Battery | DirtyLude | Electronic Projects Design/Ideas/Reviews | 5 | 13th July 2005 01:55 PM |
| Battery indicator consuming batteries | 2camjohn | General Electronics Chat | 3 | 18th February 2005 07:00 PM |
| Connect Battery and PSU at same time...? | grrr_arrghh | General Electronics Chat | 3 | 10th July 2004 12:20 AM |
