Old 6th January 2007, 10:21 PM   #1
Default triac 24v
i'm trying to control a 24v motor. can i do it by a triac or i would have to use a tr. or a relay?
thanks
trexter711 is offline
Old 6th January 2007, 10:31 PM   #2
It's an AC motor I presume? You should onyl use a TRIAC with an AC motor.
TRIAC - switching speed control
relay - just on or off for continuous periods of time
Tr. = transformer? That's only needed if your source voltage is different from the motor voltage (and you would use it in addition to a switching device).
Regarding the switching speed control, it's not as simple like PWM with DC motors. I don't know much about variable speed AC drives so...Most AC motors are designed for constant speed operation.
dknguyen is offline
Old 6th January 2007, 10:33 PM   #3
You can control an AC motor with a triac but for a DC motor you need to use a transistor, bipolar or mosfet. A little more detail on what you want to do would help.
Russlk is offline
Old 6th January 2007, 10:33 PM   #4
I'm assuming this is an AC supply, otherwise you want to use PWM and a MOSFET not a triac.
That depends on whether it's an squirrel cage or universal motor; the latter will work and the former won't.
if I know the answer.
Hero999 is offline
Old 6th January 2007, 10:34 PM   #5
yes dknguyen it's an ac motor. my question is :the triac works with 24v? (i know it works with220v)
Old 6th January 2007, 10:35 PM   #6
Yes, a properly rated TRIAC should work just fine. I don't think there is a problem with using a TRIAC that can handle 220V in a 24V circuit as long as you can meet the switching requirements in the same way you can use a 800V FET in a 24V circuit.
24V AC is a bit strange though...
dknguyen is offline
Old 6th January 2007, 10:48 PM   #7
More importantly what sort of AC motor is it?
It will only work with universal motors.
Hero999 is offline
Old 8th January 2007, 01:16 PM   #8
if its a Universal AC-DC Motor, you can also use an SCR (like BT169 , if the current is small ),
but the input AC should be made into pulsating DC using a Full wave bridge rectifier
arun
nura100 is offline
24v, triac
Triac light bulb flasher ElectroMaster Electronic Projects 23 29th September 2009 10:31 AM
Triac problem. robyelectron Electronic Projects Design/Ideas/Reviews 0 2nd August 2005 12:15 PM
triac connection Hihi Electronic Projects Design/Ideas/Reviews 4 5th July 2005 09:31 AM
555 Triac MAC15SM pop General Electronics Chat 4 6th March 2005 02:06 PM
Triac Gate Pulses pop General Electronics Chat 0 15th February 2005 11:54 PM
