Old 6th January 2007, 06:15 PM   #1
Unhappy PCB layout for TDA1557Q
Hi all,
i'm new to this forum and i want to make a power amplifier with TDA1557Q.
Can anyone please provide me the layout.http://www.electro-tech-online.com/i...cons/icon9.gif
Unhappy
syber is offline
Old 6th January 2007, 08:07 PM   #2
That circuit is so simple it doesn't need a PCB!
Look at the datasheet to see how much current it uses for the load and supply voltage.
Now use a trace calculator tool to work out the trace width you require for each connection.
http://www.geocities.com/capecanaver...TraceWidth.htm
if I know the answer.
Hero999 is offline
Old 6th January 2007, 08:17 PM   #3
Doesn't the datasheet give an example PCB layout?, they often do for such amps.
Nigel Goodwin is online now
Old 7th January 2007, 05:15 AM   #4
none of the datasheet i've found give the pcb layout and the main problem is it will not compatible with normal 2.54mm veroboard.
syber is offline
Old 7th January 2007, 11:15 PM   #5
Make yourself a PCB then; it's not that hard and there's plenty of info on how to do it on this forum, just use the search feature.
Hero999 is offline
layout, pcb, tda1557q
Clap switch - circuit + layout the_music_man Electronic Projects Design/Ideas/Reviews 2 17th May 2006 04:18 PM
DC-DC layout efficiency evandude General Electronics Chat 1 26th April 2005 11:25 AM
software for PCB LAYOUT garg29 General Electronics Chat 2 24th April 2005 07:20 PM
Layout Question -- need good reference material Brocktune General Electronics Chat 2 12th May 2004 07:13 PM
Breadboard layout software gjpollitt General Electronics Chat 3 11th January 2004 09:42 AM
