Hi, From the datasheet, the recommended R1 is 240 hm:, can I replace this with other value like 270 hm: or 220 hm:? I plan to make a power supply with a 24-0-24v transformer (8VA). I'm using 5k hm: variable resistor and a 500 hm: variable resistor in series to adjust the output voltage (R2). And a 220 hm: as R1. So I can adjust the voltage up to 30V? I don't use high current, only below 1A.Thanks
__________________ bananasiong | |
| | #2 | |||
hm: is recommended for the LM317, 120 hm: is recommended for the LM217 and LM117.Quote:
That would work but the maximum current will be well under 1A and the LM317 will be toasted if it's short circuited - the maximum input-output differential is 40 and your transformer will supply 66.5V. If you're planning to use just one 24V winding then you'll need a huge filter capacitor because the input will be only 32.5V+ ripple. Also be warned that AC voltages above 25V and DC voltages above 60V are classified as dangerous.
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. | ||||
An alternative solution would be to use the 24 - 0 - 24 with a 2 diode rectifier rather than a rectifier bridge. If you connect the anode of one diode to one 24V winding and the anode of the other to the other 24V winding and connect the cathodes together you have a full wave rectifier with only one diode drop rather than 2. Connect a filter capacitor from the cathodes to gnd and connect the 0 to gnd.
__________________ Len | |
No, I don't use bridge rectifier. Like ljcox said, I'm using only 2 diode to rectify. And I'm using a 1000 uF filter capacitor, should be enough right? About PTC, I ask it from a electronics shop and they say this is only used for air conditional and television but not in a power supply o.O?? The PTC they have looked like a relay (the size and shape), some with 3 pins and some with 2. They ask me whether I want a NTC or not, then I don't buy either from them, confusing. So which one should I use? Can I make a power supply like a PSU, when +ve and -ve terminal are shorted, the relay inside is switched and a led indicator shows that the current is not enough. Is this possible? So that the LM317 will not be toasted. If I use a 24-0-24 transformer compared to a 30-0-30 transformer, for the same application, which one uses more electricity? Is is the 30-0-30 transformer? Because the power dissipated by the voltage regulator is more. Thanks
Hi Banana, Use 120 ohms for the fixed resistor. If it has a higher value and the load is suddenly reduced, the output voltage will rise and blow up the circuit you are powering with this supply. The LM317 won't be toasted because it is smart: 1) If the output current is too high it limits the current . 2) If it gets too hot it shuts down then stsrts working again after cooling. 3) If it has more than 15V across it then it reduces the output current. Yours will have an input voltage of 33V. If its output is adjusted to 5V then it has 28V across it and it reduces the current to from 400mA to 700mA. Your little 8VA transformer is a fire hazzard. It should be 75VA (34V x 2.2A).
| | #6 |
Oh, I just bought a 8VA transformer. If I want to remain using this, the load current mustn't be greater than 235 mA right? EDIT: 1 V drop after crossing the filter capacitor, is this true for all the load current or all the value of capacitor?
__________________ bananasiong Last edited by bananasiong; 7th January 2007 at 09:14 AM. | |
| | #7 | ||
__________________ Uncle $crooge | |||
| | #8 |
Oh!! I should plan this well! I thought I can have 1 A maximum load for this power supply, but I need at least 34 VA transformer.. the size of the transformer becomes bigger if the VA rating is larger right?
| | #9 | |
If it has a 34VA transformer then its output current can be 1A only for high output voltages. At voltages below 19V it will have more than 15V across it and it reduces its max current. It also gets pretty hot. If you use a 12V-0V-12V transformer then all of it can make 32.5VDC so the LM317 can provide 17.5V to 30.0V at 1A. Then half the transformer can make 15.5VDC so the LM317 can provide 1.25V to 15.5V at 1A. The amount of heat will be reduced a lot. You could make a circuit that automatically switches the transformer to the proper voltage depending on the setting of its voltage adjustment pot.
| | #10 | ||
__________________ bananasiong | |||
| | #11 |
A 12V-0V-12V 34VA transformer can use all its secondary with a bridge rectifier to make 32.5VDC. Then a relay can switch the bridge rectifier to use only half the secondary to make 15.5VDC. Then the LM317 will provide 1A at any voltage and will not get too hot. A comparator can sense the output voltage to switch the relay. Your 24V-0V-24V 8VA transformer is not suitable.
| | #12 | |
| | #13 |
Ya, I didn't calculate well. I've done a 5 volts power supply with a 9-0-9 3VA transformer to run a PIC, I can even adjust it to maximum to program a PIC at 13V. The PIC doesn't use much current. So I have to change my transformer, a 12-0-12 with at least 34 VA using bridge rectifier. Use all the secondary? Means including the center tap? Thanks
| | #14 | |
| | #15 | ||
| lm317, power, supply |
| Got a new EVBoard How do i supply power to it? | cubdh23 | Micro Controllers | 2 | 3rd August 2007 10:39 AM |
| 24v DC Power Supply (Help & Information Wanted Urgently) | ampthetex | Electronic Projects Design/Ideas/Reviews | 5 | 17th November 2006 01:45 PM |
| Power Supply Failure | Joel Rainville | General Electronics Chat | 8 | 24th August 2005 02:42 PM |
| Query on power supply using LM317 | t_malavika | General Electronics Chat | 2 | 26th January 2004 02:55 AM |
| Low current power supply from stored current. | McGuinn | Electronic Projects Design/Ideas/Reviews | 12 | 20th January 2004 07:15 AM |
