Hello Guys, I want to improve my remote car alarm system in order that when the alarm goes off it honk the car factory horn + the alarm siren but when I arm/disarm the alarm I just want the siren to chirp and not the horn. Please keep reading so you undertand what I need. I just install a Hornet 727T alarm in my car. The alarm brain comes factory with a Positive 12V 1amp output wire to drive a 128 db siren, a Negative 200 milli amp 1 seg pulsed output wire to drive the factory car horn RELAY to make it hunk and it has a built in relay that supply a Positive 12V 10 amp output wire to flash the parking lights. When the alarm goes off the siren sound continually, the horn hunk every one seg and the parking lights flash. When I arm the system via remote control, the siren chirp one time, the horn hunk one time and the lights flash one time. When I disarm the system via remote control, the siren chirp two times, the horn hunk two times and the lights flash two times. As you can imagine the horn hunk during arm/disarm is driving my neighbors crazy:-( I have read the instrucction manual and there is no way how to solve this. Also, I write on a car alarm forum and everybody toll me the same. So, I want to assembly a electronic project that can make the Horn Hunk "ONLY" when the alarm goes off but not hunk during arm/disarm...........I just want only the siren to chirps confirming that the alarm is armed/disarmed. Can you guys help me with electronic diagram that can go conected with the alarm ouput wires described above to solve my issue? Keep in mind that I need a negative output wire that provide a 1 seg more/less intermitent pulse to drive the factory car relay/horn ONLY when the alarm goes off. The output have to be strong enougf to drive the factory relay and it need to be protected in some way in order that the feed back from the horn relay coil does not damage the electronic gadget............. Also,if it necesary, I can find the factory horn relay under the dash and solder a diode across the horn relay coil in order to protec the gadget. Just le me know. If you need aditional info, just let me know. Thank you for your help and time. Isaac | |
just tell your neighbors to stuff it ... almost every keyless entry system I've seen "hunks the horn" (sic) with the lock/unlock action other than that, check with your dealship - most of the systems can be configured via the fob or the factory radio / window controls
__________________ If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 | |
| | #3 | |
I check the alarm manual and eaven that it have many features that I can program it only have CHIRPS CONFIRMATION ON or OFF and if I select OFF the siren and neither the horn will chirp/hunk. So I really JUST want to have the siren confirmation. THX, Isaac Last edited by Turbo_Boss; 4th January 2007 at 10:51 PM. | ||
| alarm, car, improve, remote, system |
| 5 Zone Alarm System | ElectroMaster | Electronic Projects | 25 | 6th February 2007 03:42 AM |
| auxiliary automotive alarm system | gizmo13 | Electronic Projects Design/Ideas/Reviews | 2 | 16th August 2006 12:16 PM |
| Offer:parking sensor and car alarm system | Enjoy | Electronic Projects Design/Ideas/Reviews | 0 | 25th June 2003 07:54 AM |
| i need a circuit diagram of pic based alarm system.. | BurhanUnalmis | Micro Controllers | 0 | 26th April 2003 03:44 PM |
| i need a schematic of pic based alarm system..help me please | BurhanUnalmis | Electronic Projects Design/Ideas/Reviews | 0 | 26th April 2003 03:43 PM |
