Some questions related to LM567 (tone decoder)
I'm working on a project. My duty is that: I have to detect a signal radiated from an IR LEDs. I use the SFH506 to demodulate the modulated signal (carrier frequency is 40kHz). I know the information frequency, it is: 40 Hz. I have to detect this frequency. My tutor said that, I should use the IC LM567 to detect this frequency. When this frequency signal is applied to PIN 3, the output PIN 8 will be at LOW (other cases, PIN 8 always be HIGH). When I carried out the experiment. I've got some problems. - central frequency of LM567 is defied by R which is connected between PIN 6 and GND and C which is connected between PIN 6 and PIN 5. I chose R and C so that, the central frequency is 40 Hz (fo=1.1RC). Besides, I put between PIN 2 and GND a capacitor - I decided to try this case: links PIN 5 (pulses with duty cycle is 50% and f = fo) to PIN 3 (input). I hope that PIN 8 will change its state (from HIGH to LOW). But it's not the case. I use oscilloscope to display pulse shape at PIN 8 when I apply the link between PIN 5 and PIN 3, first, the pulse shape on oscilloscope appears, then the duty cycle of this pulse decreases so after about 10 seconds, it's GND (Voltage at PIN 8 equals to 0). When I remove this links, the LOW state of PIN 8 maintains and after 10 minutes observing, this state does not change. - first, I don't know why? I think, when there's no signal at the input PIN, the output PIN must be HIGH (not LOW forever). - second, does LM567 operate as I said before? that is: when there's a signal with frequence within its bandpass (fo +/- num), output PIN will be LOW and be HIGH again vice versa (opposite case). - Last, Can some one recommend me some other solutions to my problem (detect a fixed frequency signal)? My due date is coming soon and I really need your helps thank in advance! Binh, From Vietnam.
L\'amour C\'est pour rien |
Your circuit equal with this?
The PIN 3 is connected to PIN 5 between Resistor 2.5K and capacitor 0.004 mfd.
I'll post my schematics later if possible!
You can make your own IR receiver with a photodiode and amplifiers - but it's not a trivial task, and an IC receiver is so much easier.
The IR receiver IC's are in almost everything that has remote control, take one out of an old TV or VCR. |
I understand but i have use the ic's and i can't achive the distance because i have to send data.I can't send data.I don't have the space and it is expencive.So i have to use a phototransistor and take the frequency on my own with the way i explain before.I want to make sensors that detects objects.Can i achive this distance with the way i explain?Thanks |
I don't see as a simple 8 pin PIC is 'expensive'?, and that would do everything you need at the transmitter, and one at the receiver as well.
If you want to use plain frequency modulation then go the photodiode and amplifers route, but it's FAR more difficult and much more expensive. |
