Old 27th December 2006, 09:19 PM   #16
When the current through an inductor is interrupted in theory an infinite voltage is produced for zero seconds, in pactice a resonant circuit it formed with the parasitic capacitance in the inductor, the maximum voltage is simply the Q multiplied by the applied voltage.
There are many other manufacturers around but MAXIM make step-up regulators with input voltages as low as 0.7V
http://para.maxim-ic.com/cache/en/results/4631.html
if I know the answer.
Hero999 is offline
Old 28th December 2006, 05:30 AM   #17
Yes, maxim has many dc to dc step up converter, but many of them are QSOP package.
Does anyone have idea how to solder a QFN ic? That's too small, I have not idea..
bananasiong
bananasiong is offline
Old 28th December 2006, 06:02 AM   #18
I think you can use an oven maybe? Hot air? Either way it seems you require solder paste which is a pain in the ass.
I think I also heard somwhere to run the traces so that they extend beyond the edges of the chip, then you can just use a soldering iron.
dknguyen is offline
Old 28th December 2006, 07:44 AM   #19
But QFN seems to be 'Flat No Lead' type, need very strong soldering skill. If I use UV type PCB, do I need to remove the green film before soldering? Usually I don't remove it, but sometimes it cause the soldering iron to be dirty if u give too much heat.
bananasiong
Old 28th December 2006, 01:34 PM   #20
They do ready-made evaluation boards for some of the more popular ICs but they're expensive but worth it if you want to save the effort.
Hero999 is offline
Old 28th December 2006, 05:29 PM   #21
Before the Holidays I looked thru the MAX collection and came to the same conclusion that there are very few with DIP packaging. But there are a few: I did get 3 to play with, the MAX633, MAX643 and MAX743.
Haven't done anything with them yet, got a few other projects to complete first.
-- Dan
Revolvr is offline
Old 31st December 2006, 04:19 AM   #22
Here are two piccies attached with a joule thief i built a while ago and still has a blue LED going reasonably bright at 0.377 Volts.
A half full AA battery lasts for about 2 days.
http://i123.photobucket.com/albums/o...O/DSC02024.jpg
http://i123.photobucket.com/albums/o...O/DSC02023.jpg
Please don't sent me private messages, I will not answer them.
The questions asked can be discussed in the open forums.
http://www.youtube.com/user/RODALCO2007 some interesting electrical stuff to watch.
RODALCO is offline
Old 31st December 2006, 03:13 PM   #23
Wow I bet that ferrite core inductor radiated a lot of RF energy.
Hero999 is offline
Old 31st December 2006, 04:50 PM   #24
Wow, is that super bright?
Hero999, do you mean this coil can interfere with other RF devices?
bananasiong
Old 31st December 2006, 04:51 PM   #25
Yes........
Hero999 is offline
booster, voltage
DC Voltage Booster ketchumwt Electronic Projects Design/Ideas/Reviews 13 31st August 2009 06:50 PM
Resistors Marks256 General Electronics Chat 57 16th May 2009 11:22 PM
Voltage ElectroMaster Electronic Theory 44 8th August 2007 06:35 PM
I am not getting ripple voltage at the output dar2525 General Electronics Chat 3 14th July 2005 03:21 PM
