Old 25th December 2006, 07:06 PM   #1
Default need help in PCB fabrication
Hi i'm new to pcb fabrication.
Can any one please tell me what is the easy way of pcb fabrication. I'm staying in india and here Press N Peel transfer paper is not available. So please suggest me the best and the most easy way of pcb making.
syber is offline
Old 25th December 2006, 09:17 PM   #2
Most any kind of coated paper will work (to some degree...). The idea is to find paper that the toner sticks to, but not get fused to the paper fibers. After you re-fuse the toner onto the copper, soak in water. The paper breaks down, toner stays on the copper.
Most important thing!!! Clean the copper very well, and don't get finger prints on it before transfering the toner.
There is the photo-resist method, almost as easy, but higher cost, more chemicals, little more complicated (timing exposure, devoloping...).
Perminent markers (least desirable, but works for simple boards).
Rub-on decals (Press-N-Peel), not much better than using a pen, etchant seeps underneath...
HarveyH42 is offline
Old 25th December 2006, 09:50 PM   #3
Search the forum. There are a ton of people that have explained it. I sent a quick version to a fellow last week. Will cut and paste if I can find it..
Found it.
YOU NEED:
Ferric Chloride
plastic flat bottom bowl
plastic knife (to move and remove board)
copper clad board
laser printer
eagle cad
picture paper (glossy business paper works best, photo paper worse)
an iron
a drill
Think that is it.
MAKING THE BOARD:
Print the PCB on the picture paper and cut to size
Cut copper to match paper size
Clean the copper (very important part) I use wet sand paper, you can use  ajax as well
Wipe copper with denatured alcohol
put paper on copper.
heat iron on max heat
put a paper towel over paper and board.
press iron straight down center of iron on board  * hold for 30 seconds *
remove iron for a couple second and repeat * straight down and hold for  30 seconds *
(that part make the paper stay in place on the copper)
now slowly iron for 30-60 seconds, make sure you get the edges of the  board, they are the hard part.
After done, let it cool (turn of that iron too)
Get a cup of warm water, sometimes a drop of dish soap (soap is not required)
drop in the board.  Wait 5-10 minutes.
replace warm water with board in cup, and use thumbs to rub the paper  off layer at a time, sometime paper falls off  (but not often)
with thumbs remove any paper film.
ETCHING THE BOARD:
You can use a plastic flat bowl or a ceramic (if ceramic you can warm  the ferric chloride as that helps)
fill enough to submerge the board.
I put the board face down but make sure you move it around and the face  is under the acid.
If you move it on occasion for about 15 minutes, with the plastic knife,  you will see the copper is gone.
remove it, rinse it.
I use acetone to remove the toner
clean up my mess
and drill the board with my old dremel press.
That is it..
mramos1 is offline
Old 26th December 2006, 02:00 AM   #4
I've never tried it, but you can buy teflon sheets the thickness of paper, should work as good or better than most other methods I've heard about.
straight answer, har har."
Sceadwian is online now
Old 26th December 2006, 02:28 AM   #5
Where can you get them (teflon paper) and will the laser like them? I will try it.
The transparent plastic paper is $$$. Why I went to picture paper and then found the business gloss paper..
mramos1 is offline
Old 26th December 2006, 02:57 AM   #6
Default Dremel Work Station Model 220
Originally Posted by mramos1
(snip)
(snip)
[/code]
I just bought a Dremel work Station model 220. And promptly ruined several boards (stacked). This unit is a piece of junk, the downward motion is not smooth and the lateral movement is unpredictable, due to much slack. All because of poor design, no rack and pinion and cheap plastic castings.
What is the model of your unit and is it all metal with a rack and pinion?
I might buy an older model if they are any better than the 220.
Rolf is offline
Old 26th December 2006, 03:08 AM   #7
I'd be pretty surprised if toner actually stuck to teflon in the first place though. I'd expect nothing better than a big toner smear coming out of the printer. After all, even transparency sheets have to be specially coated to be used in printers, and those aren't as slippery as teflon...
I've never heard of anyone using that method, but of course that doesn't mean it can't work, just speculation. I'd be interested to hear of results if anyone tries it.
You just bought it recently? I had a very bad experience with the original model 220, which had a mechanism consisting of the sliding portion riding on a metal rod, moved by a curved slot cut into a metal bracket on the lever... is that the same one you have? I bought that one well over a year ago and it was so bad, I complained to dremel and apparently they stopped making it around that time because of similar complaints. They ended up replacing mine with the newer version when they finished it, and I have been using that one for quite some time now - it uses a rack and pinion, and although it's still largely plastic it has enough set screws and other adjustments that it can be solid enough to drill PCB's just fine. I can drill hundreds of holes with my tiniest carbide PCB drill bits without breaking any. However, someone else that I recommended the 220 to after that bought one, confirmed that it was in fact the newer version, but said it was terrible. I am kind of wondering if maybe I got some special version, rather than the model that actually went into production - if the one they're actually producing now is not as good as the one they sent me, then I'll stop recommending it to people!
EEgeek.net
evandude is offline
Old 26th December 2006, 12:09 PM   #8
I am sure mine is not the 220, it is probably 15-20 years old. I have the battery operated demel in it, that does not fit, wrapped in rubber straps.
But works well. No wobble at all. Only plastic are the knobs and the straps that hold the dremel. Just looked, it is a model 210. But old as heck. The base goes up rather than dremel coming down to the board.
mramos1 is offline
Old 26th December 2006, 02:49 PM   #9
My $50 harbor freight "tabletop" drill press will take my smallest drill bits, and works perfect. Weighs about 50# so it's nowhere near as portable as a dremel though... Lately I've tried using glossy photopaper and it worked good for a while (even made some doublesided boards) - then all of a sudden I can't get the toner to transfer! Even on high heat with lots of pressure..... So I don't know what's going on.
technogeek is offline
Old 26th December 2006, 03:03 PM   #10
Main thing is clean copper. Also, the photo paper only have the gloss on one side.
I use the glossy business paper (it is on both side) as well, very easy to iron on and soak off with water..
Hammond Business Gloss paper.. 300 sheets in a pack.
I want to get a drill press from HF but I am out of room with the blast booth and 14" band saw, overkill but man can get cut PCBs.
mramos1 is offline
Old 26th December 2006, 03:42 PM   #11
Default Dremel Work Station 220
Originally Posted by evandude
(snip)
The one I bought was second hand (hardly used), according to seller. Dremel has now replaced it with the 220-1 as far as I can tell but they look identical, so there is a question of how much the newer model has been improved.
Are there anyone that has experience with the 220-1 out there?
Older models pop up for sale now and then but I am trying not to make the same mistake again.
Rolf is offline
Old 26th December 2006, 04:14 PM   #12
I have that same Drill Press. It Works Great.
I No Longer accept Private Messages on here.
All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\"
or they go Directly to my Junk Mail Folder.
Email me at: chemelec@hotmail.com
Website: http://www3.telus.net/chemelec
chemelec is offline
Old 26th December 2006, 04:36 PM   #13
Wow, I hadn't seen that one before! I just found a picture online and it appears to have gone back to the same kind of pin-in-groove mechanism that the first one used, instead of the rack-and-pinion of the (rather short-lived) version that I have...
In that case, I hold out very little hope for it...
Well, now I guess I'd better recommend something better:
PZ541 Vertical Drill Stand from minicrafttools.com
That is what I bought when my first dremel model 220 turned out to be junk, before they had sent me a new one - it's completely metal, rack and pinion, and it works very well. It's got a big clamp that goes around the main body of the dremel, but it should be able to fit a wider variety of tools this way. it fit my regular 2-speed dremel perfectly. It's also very small compared to the model 220.
EEgeek.net
evandude is offline
Old 26th December 2006, 06:56 PM   #14
I like this thing, not for PCBs, but that would be handy as heck.
MB592 Versatile Drill Holder
$21.95
mramos1 is offline
Old 27th December 2006, 03:26 AM   #15
Default Replacement for the 220 Dremel Work Station
Found a Sears Craftsman Model No. 572.53169 for $39.95, don't know if it was on sale. (I forgot to ask because I got to excited!) It just about the same size as the Dremel and my cheap Chinese drill motor ($19.95 - $24.95 warable speed) fits perfectly. The Sears unit has a rack and pinion and enough adjustment screws to make it operate smoothly and accurately.
Warning about the Chinese Dremel imitation, its collets are NOT the same size as the Dremel but I have made them work anyhow. Other wise it is a fine unit for the money. It comes with a flex drive, in a nice box and slew of grinding, sanding and polishing tools.
Rolf is offline
fabrication, pcb
PCB Fabrication FusionITR General Electronics Chat 6 18th August 2006 08:39 AM
fabrication of a transistor 4electros General Electronics Chat 2 12th May 2006 08:12 PM
PR in NMOS fabrication 4electros General Electronics Chat 5 9th May 2006 04:54 AM
Help with fabrication and design of mechanical parts mayhem Robotics Chat 7 9th March 2006 05:52 PM
Photo fabrication for PCB's Johnson777717 General Electronics Chat 2 25th June 2004 05:48 AM
