Old 23rd December 2006, 02:07 AM   #1
Talking Before i apply this ckt to my laptop...
hello,
Before i apply this ckt to my laptop... i just wanna make sure everything is ok.
it is an ISP programmer for the AT89S52.
it will be connected to the // port of my laptop.
I am using AND gates as buffer (just because i don't have a dedicated buffer IC right now, and can't wait to get one)
just wanna make sure that my approach is correct. I know it is a VERYYYY simple circuit.. but.. as i told.. its my poor litle darling laptop we're talking about here! so, i m just waiting for a confirmation to build the ckt.
final note: if the laptop blows up killing me and the people living in my building, don't worry i won't blame anybody here for it!
Ibrahim Kamal
check my electronics and robotics page: http://www.ikalogic.com/
ikalogic is offline
Old 23rd December 2006, 02:10 AM   #2
oooooops forgot to tell you, the last gate is inverted w/ reguard to the others, because this last one is to buffer an input (rather than an output like the others...)
Ibrahim Kamal
ikalogic is offline
Old 23rd December 2006, 02:45 AM   #3
It is an old TTL gate. Its minimum output high voltage is only 2.7V and won't drive Cmos without a pullup resistor. Its output current is low but OK for logic.
audioguru is online now
Old 23rd December 2006, 02:56 AM   #4
But it will be used to to control I/O pins of a TTL mircocontroller... i don't think we need more current. do we?
thx
Ibrahim Kamal
ikalogic is offline
Old 23rd December 2006, 03:04 AM   #5
It looks OK. About the only thing that you could do to ruin the port would be to apply power backwards to the circuit or maybe apply 12V instead of the 5V. Power it up first when it is not connected to the laptop and make sure that all voltages relative to ground (pins 18-25) are between 0 & 5V on pins 6,7,8 & 10 and you should be safe.
But it's not a vacuum tube!
kchriste is offline
Old 23rd December 2006, 03:11 AM   #6
The filament in an old TTL gate (compactron?) eats power and makes the IC warm. Hee, hee.
I would use a 74HC08 which is Cmos with a very low supply current, an output that goes to +5V and to 0V and has 25mA source or sink current. The same as in microcontrollers.
Old 23rd December 2006, 08:35 AM   #7
Over current resistors aren't going to hurt.
straight answer, har har."
Sceadwian is offline
Old 23rd December 2006, 01:40 PM   #8
Exclamation
thanks, but.. which value to use... i guess 470 would be suitable? or maybe 220 ?
Ibrahim Kamal
ikalogic is offline
Old 23rd December 2006, 02:08 PM   #9
If you ever want to drive old 74xx TTL logic or LEDs, then use 120 ohms.
Old 24th December 2006, 03:40 AM   #10
hello, thanks guys, by the way i just made the ISP programmer to work...
but i was really unlucky, i passed through all the bugs one can pass through when building this circuit , e.g.:
-Too long cables
-Noise,
- 2 defectious AT89S52 chips,
-Parallel port configuration (EPP, SPP..)
Anyway, just letting you know guys, if anyone is in trouble building his ISP, i may help!
Ibrahim Kamal
ikalogic is offline
Old 6th January 2007, 05:57 AM   #11
my ISP programming cable is done:
http://www.ikalogic.com/isp.php
I wouldn't bother saying, i hate to be anoying! but i know some guys here like to see the results of the projects dicussed in the forum..
Ibrahim Kamal
ikalogic is offline
Old 6th January 2007, 02:56 PM   #12
I can't believe these things were made up until the early 1990s
http://en.wikipedia.org/wiki/Compactron
if I know the answer.
Hero999 is offline
apply, ckt, laptop
Feeding video into a laptop sram Electronic Projects Design/Ideas/Reviews 20 1st January 2007 08:23 PM
Blank screen on laptop WetRat Datasheet/Parts Requests 0 10th February 2006 12:08 PM
How to show a PC display on to a laptop ?? john1 Electronic Projects Design/Ideas/Reviews 9 9th January 2005 07:58 PM
Laptop to car speakers curcuit board PaulD Electronic Projects Design/Ideas/Reviews 3 25th July 2004 08:46 PM
Laptop For Trade! Trade For Desktop Computer! + MORE *LOOK!* mobiledreamz General Electronics Chat 10 21st January 2004 10:28 PM
