Old 21st December 2006, 02:37 AM   (permalink)
Default Trigger 555 with positive pulse
I need to trigger a 555 timer with a positive pulse instead of the negative pulse required. Using a 2N2222 transistor, how can I calculate the base resistor and collector resistor needed? I will have the emitter tied to ground.
Thanks.
Greg
ghall426 is offline   Reply With Quote
Old 21st December 2006, 02:45 AM   (permalink)
Default One more thing
By the way, I tried using the circuit negative triggering as the 555 is designed but the trigger was so sensitive it would trigger by the touch of my finger. I tried a 200 ohm pullup resistor, but my finger could still trigger it. So I am assuming the transistor idea is the way to go and change my trigger mechanism to a positive pulse.
Greg
Old 21st December 2006, 03:33 AM   (permalink)
With a 200 ohm pullup resistor from pin 2 to the positive supply your finger must be 100 ohms to ground (you are standing in a bucket of salt water?) to trigger a 555, or your finger picked up a strong radio station nearby.
Have you ever seen the shielded cable used for microphones and stereo components? It stops pickup from radio stations and mains hum.
Old 21st December 2006, 04:42 AM   (permalink)
A rule of thumb for making a saturated transistor switch is that the base current should be 1/10 of the required collector current. So,.... If your input voltage is the same as your output, the base resistor is 10 times the resistance of the collector resistor.
For your 555 circuit, try a 10K on the base and a 1K on the collector. A 2n3904 or 2n2222 should work fine as will almost any small NPN transistor you might have around.
The 555 doesn't need much "time" to be triggered so the large pulse of current accross the 200hm: most likely came from your body capacitance and static charge. To guard against these types of triggers you can shield it, like Audioguru said, or use a lowpass RC network on the input to the 555 to filter out the highspeed pulses.
kchriste is offline   Reply With Quote
Old 21st December 2006, 08:10 AM   (permalink)
Why don't you use a Monostable instead of the 555? Then you only need a capacitor and a resistor since Monostables are edge sensitive.
Len
ljcox is offline   Reply With Quote
Old 21st December 2006, 02:54 PM   (permalink)
Don't bother doing any calculations, just use the values in the diagram below.
Screen name: Aloone_Jonez
Old 8th June 2008, 05:15 PM   (permalink)
Would that circuit be suitable for triggering a 555 using the output from an amplifer.
I am trying to build a sound to light circuit for a strobe light. Here is my original post: http://www.electro-tech-online.com/e...r-circuit.html
simontay1984 is offline   Reply With Quote
Pulse in negative and positive transition leonel Electronic Projects Design/Ideas/Reviews 12 5th January 2006 07:59 AM
+5v pulse to trigger 4013 Flip Flop RaG Electronic Projects Design/Ideas/Reviews 3 31st January 2005 01:44 AM
pulse delay problem between 2 schmidt trigger segments Dialtone General Electronics Chat 2 15th November 2003 02:32 PM
project for trigger pulse so as to have fase control tsoupl Electronic Projects Design/Ideas/Reviews 4 13th November 2003 06:49 PM
Pulse Width Calculation waqar Micro Controllers 1 25th June 2003 11:53 AM
