Old 20th December 2006, 12:47 PM   (permalink)
a white led can be your shunt diode too, and it's around 3 to 3.3 volts ... of course, you'll only get 10-30ma from it, unless it's a power led.
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline   Reply With Quote
Old 20th December 2006, 05:41 PM   (permalink)
Thanks a lot for you all. So...if I put 3 diodes (1N4004) in series on the "5v positive rail" I will get (more or less) 2.9 volts. Do I need to do the same to the "negative" - diodes in reverse to get -2.9? (...sure this question will make everyone understand how beginner I am). Again thanks a lot.
prprog is offline   Reply With Quote
Old 20th December 2006, 10:02 PM   (permalink)
no, you just need them on the positive rail. Whether or not it is a good enough solution depends on your application. if your circuit will work off a not-very-consistent supply voltage then it might be fine, if your circuit is going to be sensitive to supply voltage then it is probably a bad idea.
Since you mentioned the 'tuning' of your circuit and its relation to the supply voltage, I would suspect that using diodes might be a poor choice.
EEgeek.net
evandude is offline   Reply With Quote
Old 21st December 2006, 04:39 PM   (permalink)
heres another solution
http://www.futurlec.com/Mini_Logic.shtml
bbarney is offline   Reply With Quote
Old 21st December 2006, 06:02 PM   (permalink)
The OP is looking for a way to regulate a 3v power rail, not to convert logic levels... The only part of that board that would be useful for this would be the 3.3v regulator on it, which could just as easily be purchased alone...
EEgeek.net
12 volts from two 9 volt batteries sandmantoy Electronic Projects Design/Ideas/Reviews 9 22nd April 2006 01:02 PM
12 to 5 volts Loki General Electronics Chat 8 10th December 2004 03:04 AM
Reducing voltage from 9 to 5 volts Pallen33 General Electronics Chat 55 16th July 2004 04:02 PM
220/240 volts sandmantoy General Electronics Chat 20 5th May 2004 02:24 AM
3.7 volts LED with 2 volts Grimchuck General Electronics Chat 9 27th April 2003 04:25 PM
