Old 18th December 2006, 05:10 PM   (permalink)
Default Voltage Range Conversion
A circuit is required to convert a voltage range of 100mV - 1V to 1V -5V
ie:at i/p:100mV --> o/p: 0V and
1V---->5V
Any ideas/suggestions ?
Electrix is offline
Old 18th December 2006, 05:12 PM   (permalink)
Give more details, that's far too vague and gives no indication of what you're trying to do!.
Nigel Goodwin is online now
Old 18th December 2006, 05:18 PM   (permalink)
Lets say we have a sensor giving out readings in the range of 100mV-1V.
I want to calibrate these such that 100mV should correspond to 0V and 1V should correspond to 5V. All the readings in between 100mV & 1V, likewise should be mapped.
Electrix is offline
Old 18th December 2006, 05:32 PM   (permalink)
offset the input signal by 100mV and then put the offset signal into a gain stage of 5.56
OutToLunch is offline
Old 18th December 2006, 05:38 PM   (permalink)
Unhappy
That should do it, I think. Can you draw a schematic that does this. (offset it and amplify the resultant).
Electrix is offline
Old 18th December 2006, 06:03 PM   (permalink)
Check out opamps! - tailor made for a job like this!.
Old 18th December 2006, 07:21 PM   (permalink)
A non-inverting adder with a potentiometer on one input leg will allow you to adjust the input voltage offset. With appropriate feedback resistor, you can also get the gain desired. Is that enough information?
"Everything that is done in the world is done by hope." -Martin Luther
"There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein
Analog is offline
Old 18th December 2006, 07:40 PM   (permalink)
What are you trying to do?
It's possible you're doing it the hard/wrong way.
Screen name: Aloone_Jonez
Hero999 is offline
Old 19th December 2006, 01:57 AM   (permalink)
OpAmps can definitely be a choice for such a circuit.Sorry, I've gone a bit rusty with my knowledge, its been quite a while and have lost touch ! Feels good to get back !!
Electrix is offline
Old 19th December 2006, 01:58 AM   (permalink)
Thanks ! I'll try that out.
Electrix is offline
Old 19th December 2006, 02:02 AM   (permalink)
I'm simply trying to find a solution to a problem, defined in the Third Post in this thread. The issue was of signal conversion/calibration.
Electrix is offline
Old 19th December 2006, 02:19 AM   (permalink)
The reason people are confused about your request for information is because it's such a straight forward problem. Use an opamp with the specified gain. The input impedance, output impedance and signal frequency however decide what opamp you chose.
straight answer, har har."
Sceadwian is offline
Old 19th December 2006, 10:31 AM   (permalink)
That's another point, you haven't stated what bandwidth or input/output impedance you require.
Hero999 is offline
Old 19th December 2006, 05:15 PM   (permalink)
It's a DC Signal Voltage. The impedances are not worked out as yet. I've managed to build it anyway. Thanks all.
Electrix is offline
Voltage ElectroMaster Electronic Theory 44 8th August 2007 06:35 PM
Beginner Questions: AC, Impedence, Transistors, and Salving budidharma General Electronics Chat 5 9th December 2004 09:43 PM
Ionic air cleaner project ymmy Electronic Projects Design/Ideas/Reviews 21 18th May 2004 12:10 AM
12vdc -> 7.5vdc transformer gulaz Electronic Projects Design/Ideas/Reviews 10 7th May 2004 08:59 PM
voltage range of step up transformer darmfam General Electronics Chat 2 31st August 2003 06:08 PM
