Old 17th December 2006, 10:32 PM   (permalink)
Default GPS to Serial connector
I want to build a connector to connect my explorist 200 to my computer via serial port.
Source: http://rhamphorinkx.newmail.ru/connect.htm
There schematic (http://rhamphorinkx.newmail.ru/ex_sxema.wmf) is kinda vague as to where the capicitors go and what resistor to use.
Also where is a good place to buy the components?
- Cable with 9-pin connector for serial port (Female) -HAVE
- Cable with USB connector. - HAVE
- One chip MAX-232,
- Dip-socket for this chip with 16 pin
- One resistor 1 to 5 Ohm
- Five capacitors 0.33 - 1 mikroFarad,
What kind of board should I mount it to? like a breadboard or something?
natural_orange is offline   Reply With Quote
Old 18th December 2006, 01:47 PM   (permalink)
hi ... you don't have your location filled in, so it's hard to guess where a good place to buy would be for you.
how many of these do you plan to build? there is another version of the max232, called the max233. it has the capacitors built-in, making it a lot easier to assemble. of course, this convenience costs about 3x the price of the 232, it's worth it in a one-off situation
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline   Reply With Quote
Old 19th December 2006, 01:12 AM   (permalink)
Look at page 17 of this doc:
http://pdfserv.maxim-ic.com/arpdf/MAX220-MAX249.pdf
They recommend 1uF caps for the MAX232 and take carefull note of the polarity. And yes, C4's + terminal goes to ground. This is normal because it is for the negative supply generated internally by the MAX232.
As for the resistor, that would depend on the GPS unit. I assume this is just for charging the batteries in the GPS. That's why it is labeled as optional. I would leave it out if you are uncertain.
kchriste is offline   Reply With Quote
Old 22nd December 2006, 04:37 AM   (permalink)
The Gps has to be powered since the batteries have to be removed to get acess to the connectors...
Whats a good site/store for parts?
Old 22nd December 2006, 04:45 AM   (permalink)
I'm really only planning on building one. Idk if its possible just to buy one. The MAX233 sounds like it might be better for this situation though, I'm pretty new to this stuff but i really wanna learn more about it
Old 22nd December 2006, 02:39 PM   (permalink)
Check out bgmicro.com
you'll be able to get everything on your list there, and they are pretty cheap too.
I dunno about powering your GPS off the USB, but I guess the website says it'll work. I tried that with mine, Garmin GPS III, and the usb couldn't source enough current. The garmin would turn on and then shutdown once it tried to fully initialize
Favorite numbers:
serial port cud u extend it?????? jam_mafia Electronic Projects Design/Ideas/Reviews 5 15th February 2006 06:51 AM
Serial to Parallel mstechca Electronic Projects Design/Ideas/Reviews 6 30th March 2005 04:40 AM
9pin serial connector for breadboard dak246 General Electronics Chat 9 29th October 2004 03:27 PM
pic16f877 serial recieve acting screwy masconejos Micro Controllers 6 9th April 2004 10:08 AM
Can a Basic Stamp support 2 serial ports? Scruit Electronic Projects Design/Ideas/Reviews 13 15th August 2003 02:07 PM
