Old 17th December 2006, 05:05 PM   #1
Default smoke detector ?
hi there.
Does anyone have/know a simple circuit to detect smoke.What are the main part/detector name? or maybe it just can be done by just using a LED/IR LED and LDR that connected to NPN and a relay what so ever.
Note that, this is not really a critical project that is to really detect smoke in case of fire/emergency.No life will be harm if it fails to work : )
thanks.
-manz-
manz is offline
Old 17th December 2006, 05:45 PM   #2
IR tends to be scattared by smoke less than red so shorter wavelengths are probably a better choice.
You can either have the LED directly opposite the sensor and monitor it for a decrease in light or position it so not much light from the light is shining on it from the LED then look for an increase intensity caused by the light being scattered by the smoke.
if I know the answer.
Hero999 is offline
Old 17th December 2006, 10:34 PM   #3
Have you thought about using an ionization detector? This is what most smoke detectors are supposed to use and the sensativity is superior to that of an LED setup. I unfortunatly have no idea where you'd get the sensors from, aside from perhaps a junk smoke detector.
straight answer, har har."
Sceadwian is offline
Old 17th December 2006, 11:10 PM   #4
You could always, just use the entire smoke alarm PCB with the piezo transducer removed and the output driving your other circuit.
Hero999 is offline
Old 17th December 2006, 11:28 PM   #5
If you're lucky, the piezo transducer is one of the built in oscillator designs, so the signal would be straight DC going to the buzzer.
Old 18th December 2006, 12:37 PM   #6
The LED + LDR configuration, is not that bad, it is acutally used in many sensors..
you can also combine a heat sensor + smoke sensor, this how the sensors work in my university.. and BOY we allways mess around trigerring the alarm in the whole building...
Ibrahim Kamal
check my electronics and robotics page: http://www.ikalogic.com/
ikalogic is offline
Old 21st December 2006, 08:44 AM   #7
Hm I didnt know that,thanks 4 the info.
hm yup i can see the point but it would be nice if the sensors LED light is not visible to the naked eyes so that`s why I tried to used the IR LED.
Hm that a good idea but i just dont know where to get it though,do you think i need to buy a smoke detector to get it or can i just get the part only?
heat sensor - may not be suitable in my project though because i dont think there`s an increase in heat in the sorrounding eg smoking.
I have tried the setup using the IR LED and LDR :
1.the smoke that pass through the setup jus increase 200 ohm at the LDR.
2. the set up isnt so stable because it really affected by the ambient light, even i had put the LDR in a cylindrical black housing (about 2 cm) made from paper.
so maybe i need to use an IR detector instead of LDR that is to reduce ambient light effect ?? do you have any idea ?
thanks to all.
-manz-
manz is offline
Old 22nd December 2006, 12:46 PM   #8
hello,
i've seen a cute idea on a magazine long time ago..
the idea was to put 2 sets of leds and LDR, (2 LEDS and 2 LDR)
one of the 2 sets, will be used to detect smoke, the other, will be encapsulated in a transparent matter, to detect what ever ambiant light variations..
now as far as i remember they just used an opamp with a coupt of resistrs to substract the light variations from the smoke detector...
this is the main idea.. you have to dig inside..
if you'r really interessted, i'll search in my 250 electronics magazines.. but it may take some time...
Ibrahim Kamal
ikalogic is offline
Old 22nd December 2006, 02:57 PM   #9
You could probably do that with a single LED and two LDR's using a tiny plastic prism. Keep in mind too, the distance between the LED and the LDR is going to effect your results pretty dramatically. The farther away you place it the more a light smoke is going to interfere with the light.
Old 22nd December 2006, 05:32 PM   #10
Smile
Hmm i dont know what to say still.but thanks anyway.maybe the idea proposed by ikalogic have something to think of, but still waiting the search result from the 250 magazine anyone else have any idea ?
thanks again guys.
-manz-
manz is offline
detector, smoke
gas detector vyaas General Electronics Chat 2 29th May 2006 12:21 PM
Envelope Detector ThermalRunaway General Electronics Chat 13 30th July 2005 07:25 PM
RF Detector/ Mobile detector CircuitMan Electronic Projects Design/Ideas/Reviews 12 27th October 2004 04:39 PM
how to hook the output of a smoke detector? valerie Electronic Projects Design/Ideas/Reviews 1 5th October 2003 11:00 PM
Radar detector ElManu Electronic Projects Design/Ideas/Reviews 0 11th September 2003 10:01 PM
