| | #31 |
Good news! It works! Bad news! It gets really hot! At the suggestion of tech support, I connected the oscillator pin to the gate to select a "constant off time" mode as referenced in app note AN-50. This allows duty cycles >50% without subharmonic frequencies appearing. Now, it's putting out the rated 1.4A, but everything is getting really hot! The inductor and diode gets warm (to be expected), the FET gets hot, and the HV9910 gets hot! When I say hot, I mean 150+F. I put the fet on a heatsink, but not sure what to do with the 9910 - or even why it's getting hot. | |
| | #32 |
any idea what frequency it's running at? that's the only thing I can think that would make everything heat up. high freqs increase switching losses in the transistor and diode only reason I can think the chip should get hot is that it's somehow not wired correctly, or maybe you're taxing the internal regulator too much? do you have any load connected to the regulator output (Vdd pin 6) how about voltage on the feedback pin, is it within spec?
__________________ If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 | |
| | #33 |
Wow, that's strange....... According to my $50 meter, it's output is 300+khz? It's supposed to be running at 100khz. I'll have to put it on a scope to confirm that though, it might be picking up something. Very strange. Internal regulator is not used. (it's tied to LD and PWM_D) The voltage at the current sense resistor is what it should be. Last edited by technogeek; 1st January 2007 at 04:32 PM. | |
| | #34 |
Nevermind, 72khz @39% DC, which is within spec.
| led, switcher, w or hv9910 |
| Stereo Guitar Cabinet Switcher | GtarPlaya11 | Electronic Projects Design/Ideas/Reviews | 51 | 23rd December 2006 06:55 PM |
| Help with LED switcher supply | technogeek | Electronic Projects Design/Ideas/Reviews | 37 | 11th December 2006 09:46 PM |
| RF Remote control for a Video switcher | Vam | Electronic Projects Design/Ideas/Reviews | 0 | 4th October 2005 07:49 AM |
| Switcher Cad III | Russlk | General Electronics Chat | 2 | 8th March 2005 11:26 AM |
| Where to start about Switcher CAD? | rea | General Electronics Chat | 9 | 19th January 2005 09:31 PM |
