Old 6th January 2007, 04:46 PM   #61
It looks like a good IC, it's easier to use than the MAX7030 and the configureation software is another bonus.
You'll still need to use SMT componants (just less of them) and build it as small as possible.
if I know the answer.
Hero999 is offline
Old 6th January 2007, 05:56 PM   #62
The modern IC is tiny, has many pins close together and its recommended parts are surface-mount and you said you can't get them.
They say it is for short range.
The IC needs to be programmed.
audioguru is offline
Old 6th January 2007, 06:13 PM   #63
Yes it does need to be programmed, but not how you would a PIC. A microcontroller is required to load the configureation data into RAM when it's powered up.
Hero999 is offline
Old 7th January 2007, 09:06 AM   #64
Yes, I got where to buy the smt components. But I have to order for certain value of components and I have to buy 10 items for each type. Is there any smt crystal?
I think I will use the MAX7030 since I have already order the components. But I don't see any hand made coil or trimmer capacitor, can the receiver receive signal from the transmitter without tuning?
bananasiong
bananasiong is offline
Old 7th January 2007, 11:44 AM   #65
If you can't make them exactly like the manufactured ones then they need to be tuned to the same frequency or the range will be next to nothing.
Old 7th January 2007, 03:34 PM   #66
then i have to use a trimmer cap for the tank circuit? 2.7 pF trimmer cap is too small, don't know whether can get it or not...
EDIT: Does the amount of the solder affect the stray capacitance or the frequency?
bananasiong
Old 7th January 2007, 06:03 PM   #67
It has only a couple of tuned circuits and the values of the capacitors and inductors are specified. They will have a very wide bandwidth and the accurate frequency is determined by the quartz crystal.
This is UHF isn't it? It is nearly microwaves. Everything affects a tuned circuit at such a high frequency.
Old 7th January 2007, 06:18 PM   #68
Oh.. then i have to make sure both the transmitter and receiver to be the same. So difficult..
bananasiong
Old 7th January 2007, 06:27 PM   #69
Any decent quality of soldering won't be a problem, any changes will be too little to make any difference - however, if your soldering is really poor, it could have an effect?.
Old 7th January 2007, 06:41 PM   #70
I think my skill is not that poor, but I haven't involved in smt. I think I will cover a layer of solder on the PCB before putting the parts, any good idea?
bananasiong
Old 7th January 2007, 06:44 PM   #71
Tinning it first is perhaps a good idea (as thin as possible), but in any case, using liquid flux will help greatly!.
Old 7th January 2007, 06:58 PM   #72
Why should it be as thin as possible?
I always use soldering paste/flux. But what's the purpose of using it? Easier to remove the solder?
When soldering, I'm always facing this problem: some oil (or whatever that I don't know) left on the PCB after soldering and removing the components for a few times that makes the solder not to stick on the PCB.
If I use UV PCB, should I remove the film after etching?
bananasiong
Old 7th January 2007, 07:06 PM   #73
Because the components are supposed to be flat on the board!
It makes the solder flow and 'stick' - please notice I said LIQUID flux, not paste - it's really important for SM work.
The PCB needs to be PERFECTLY clean and dry, don't even touch the surface with your fingers (the grease stops the solder taking properly).
Don't know, I don't make PCB's.
Old 7th January 2007, 07:07 PM   #74
Flux does several things, it conducts heat to the joint, insulates it (compared to air) and cleans the joint as well. Without flux a lot of thermal oxidation takes place with air and can ruin the joint completly. You should always use a minimum of a denatured alcohol cleaning of the board. Drug store alcohol is a waste of your time as even the best of it (90% isopropyl even if you can find it) is still 10% water. Denatured alcohol is a pure solvent, and usually available at a local hardware store. It disolves particulates well, is cheap enough to use as a flushing liquid to remove small debris, and given even moderatly dry air conditions will completly evaporate.
straight answer, har har."
Sceadwian is offline
Old 7th January 2007, 07:17 PM   #75
How to use liquid flux? Soak the tip into it like soldering paste?
bananasiong
300mhz, module
Chip talk dreamproject Electronic Projects Design/Ideas/Reviews 8 2nd April 2005 08:24 PM
Motor control interface dreamproject Micro Controllers 0 31st March 2005 04:48 AM
controlling laser module via RF receiver mr. mister Robotics Chat 1 28th February 2005 04:45 PM
ignition module induction1 General Electronics Chat 5 25th November 2003 12:35 AM
Safety interlock module wilfredmike Electronic Projects Design/Ideas/Reviews 6 2nd November 2003 09:41 PM
