| I wanted to set up a 3 volt single LED to be able to adjust the brightness from OFF to maximum brightness. I was using a pot switch, but read this is not a good idea. I would like to have the adjustment by turning a knob or pushbutton. I could not find the parts I need. Any help/advice or links to manufacturers would be greatly appreciate. I am pretty novice at this. Thank you. | |
| The simplest method aside from using a micro controller would be building a simple 555 timer circuit and adjusting the duty cycle. As long as the frequency is above a few hundred hertz it'll appear to be on continously and the larger the duty cycle the brighter it will appear.
| Would I be able to power it off with the 555 as well? Also do you have a website link that offers the components I may need? | |
__________________ --- The days of the digital watch are numbered. --- | ||
| Thank you this is currently how I have it set-up. Unfortunately I won't the pot to serve as a switch as well and cannot find anything small enough. Any recommendations on where to get a pot switch that can handle the LED? | |
| If you use a 1M pot and a 6V battery then with the pot turned down the current in the pot is so low that a battery will last for a very long time, it shelf life. The transistor will need to be two connected as a darlington or use a darlington.
| Power supply is 3 volts. | |
| You should be able to find pots that have an off detent, a lot of consumer electronics equipment use them. What resistance that off detent provdies I'm not sure, but it's going to at least be as good as 'far left' on a regular pot, and provide a physical detent preventing accidental turn ons.
| Is this mains powered or battery?
| ULN2803A driving LEDs - brightness problem | ChrisB | General Electronics Chat | 16 | 24th September 2007 05:15 PM |
| PIC 16F84A 10x7 Display Project LED Falling Brightness. | Gayan Soyza | Micro Controllers | 2 | 24th November 2006 09:36 AM |
| Three Phase Versus Single Phase For EV | fzn10 | General Electronics Chat | 4 | 31st July 2006 09:39 AM |
| PIC: 16F How to toggle a single bit in file register | eblc1388 | Micro Controllers | 6 | 18th September 2005 12:15 PM |
| Single digit 7 segment VF displays | Eclipsed | General Electronics Chat | 6 | 12th July 2005 04:57 AM |
