+ Reply to Thread
Results 1 to 8 of 8
Thread: flashing LED,s
  1. #1
    mick the builder Newbie
    Join Date
    Dec 2006
    Posts
    3
    Default flashing LED,s
    Hi Everyone. Let me start by saying I know absolutley nothing about electronics, circuits or curcuit boards but can do what I'm told.
    I need help in making a visual panel that has two blinking led's that will run off a 12v transformer. This will be put into a dummy alarm bell box. I did buy a bell box and tried to get the led's flashing but they seemed to flash in a "triggered sequence" and then only with the battery which soon ran down.
    The idea is to create a visual ditterant by having a bell box with the led's flashing although I dont have a control panel fitted.I thought I could just wire up the box to a 12v supply and it would work.(Silly me). If some one knows how to adapt the box or can draw me an idiots guide to making a circuit board to fit in the box, I would be grateful. I would also need a list of what to buy and how to build it.Also an explanation of what bit does what so I can get a better understanding of what Im doing. Thats not too much to ask is it !!!
    Thanks in advance.
    Mick
  2. #2
    RODALCO Newbie
    Join Date
    May 2006
    Location
    Akld, New Zealand
    Posts
    937
    Default Flashing LED's
    I haven't got a schema handy here at my work, but try google and look under 555 LED circuits.
    There is a common one which flashes 2 LED's, like at a railway crossing.
    It is simple to build and uses cheap commonly available components.
    Please don't sent me private messages, I will not answer them.
    The questions asked can be discussed in the open forums.
    http://www.youtube.com/user/RODALCO2007 some interesting electrical stuff to watch.
  3. #3
    RODALCO Newbie
    Join Date
    May 2006
    Location
    Akld, New Zealand
    Posts
    937
    http://www.discovercircuits.com/L/lite-flash.htm
    Here is a link with some good LED circuits, even with normal transistors
    Cheers
  4. #4
    Join Date
    Dec 2006
    Posts
    3
    Thanks for your speedy reply. The circuits might be easy for you but for me they are lines on a page.I do appreciate your help though. Any suggestions for a site that explains simple circuits and what all the bits do?
    Cheers Mick
  5. #5
    Analog Okay
    Join Date
    Jul 2006
    Location
    Michigan USA
    Posts
    476
    You can buy flashing leds out of the box. Just connect DC and away you go:
    http://www.elexp.com/opt_6bid.htm
    "Everything that is done in the world is done by hope." -Martin Luther
    "There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein
  6. #6
    elMickotanko Newbie
    Join Date
    Dec 2003
    Location
    Dumbarton, Scotland
    Posts
    72
    Yep,
    Go to your nearest Maplins and buy
    2x flashing LEDs - order code uk37 (red 5mm, there is different sizes and colour also).
    2x 270 or 330 ohm resistors - order code M270R, M330R etc. (lower value - brighter. higher value - longer battery life)
    a battery - order code MM22. (12V 1.3Ah, 97 x 43 x 52 mm).
    a bag of wire.
    Connect +ve of battery to leg of resistor, other leg of resistor to LONGER LEG of LED, and finally shorter leg of LED back to negative of battery.
    Do this with both resistors/led (in parallel).
  7. #7
    Join Date
    Dec 2006
    Posts
    3
    Thank you very much .All this help from all around the world just so I can get two little LED,s flashing.I went on the maplin site and ordered the goods.Fingers crossed! As you all wont be able to sleep until you know how I got on, I will let you know in due course. Thanks again, Mick
  8. #8
    mkh
    mkh is offline
    mkh Newbie
    Join Date
    Apr 2006
    Location
    india
    Posts
    65
    Thumbs up
    try this simple multivibrator
+ Reply to Thread
  1. 2 flashing led circuit
    By captaincaveman in forum Electronic Projects Design/Ideas/Reviews
    Latest: 12th August 2006, 11:36 AM
  2. Lighthouse Flashing Circuit
    By NewcastleSAR in forum Electronic Projects Design/Ideas/Reviews
    Latest: 2nd July 2006, 08:34 PM
  3. LED Flashing Array! Please Help!
    By mindctrl in forum Electronic Projects Design/Ideas/Reviews
    Latest: 9th December 2004, 03:10 AM
  4. Electromagnetic Flashing Stickers
    By rahul986 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 13th July 2004, 04:22 PM
  5. Electromagnetic Flashing Stickers Circuit
    Latest: 11th July 2004, 06:02 AM
Tags for this Thread
