| I have just recieved a sample of the QT113 chip from Quantum. I've been playing around with sensitivity etc and they are a real development, I have been using capacitive switches for house lighting etc these have been run from a 12vDC power supply which also runs a 12vDC relay for switching the 240v. I want to replace any currently mechanically operated switches that remain in a home with a QT113 circuit. Whilst I have the circuit figured out, I wonder if someone can suggest a way I could adapt the 240vAC feed to the existing switches into a supply of 2-12vDC easily, I am familiar with using the 805 regulators but need to drop the voltage and switch to DC 1st. I need it to be a fairly small physical size conversion because of the limitation of space behind existing switches. I don't want to use pre-manufactured regulated adapters and have to run that supply to each switch I want to utilise the existing lighting supply. Any help would be appreciated.................... | |
| Is this - http://www.maplin.co.uk/Module.aspx?...rmer&doy=10m12 and this - http://www.imagineeringezine.com/PDF...240VAC5VDC.PDF what I need to be doing? Or Is there a way to go even smaller? | |
| Anyone?? | |
__________________ If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 | |
| Thanks!! I'll have a play around with that circuit. That would reduced the size considerably. Cheers | |
| Linear Vs Switching Regulation. | Overclocked | General Electronics Chat | 35 | 14th January 2007 05:25 PM |
| Zero Signal audio switching | gtrdude | General Electronics Chat | 12 | 12th November 2006 08:28 PM |
| Simple PNP switching problem | DirtyLude | Electronic Projects Design/Ideas/Reviews | 41 | 8th October 2006 03:20 PM |
| HID ballast/LCD projector switching spark gap symptoms | linuxglobal | General Electronics Chat | 5 | 1st April 2006 07:17 AM |
| Help! Circuit on ac/dc switching | ym2k | General Electronics Chat | 20 | 26th January 2005 08:19 AM |
